So after replacing my cooling fan and fan control resistor on my 2.4 le5, it still does not kick on, even when forced on in hpt. I decided to just buy the wiring kit for making a toggle switch and drilled a hole for the switch in my dash, got the relay all wired up properly and connected to power and ground, in this photo below I found in an old thread, these colors for the fan were mentioned. where even is the fan wire loom? I pulled my fan back out and there is no loom behind the connector I can take out. the power plug on the engine harness only has black white and gray. where would I find this “fan wire loom”
