Manual Electric Fan Switch
Old Apr 19, 2008 | 11:23 AM
biniecki's Avatar
I was at the track last night and my car gets really hot really fast and noted that the electric fans did not kick on all the time and I had to use my blower fans instead to try and get some heat away from the engine. I was wondering if anyone has rigged a manual bypass switch up to be able to turn the fans on whenever you wanted. If so could you give me some guidance on what I need to do. Thanks
Old Apr 19, 2008 | 11:26 AM
originaladrian's Avatar
yup, i have and theres a how to
just use THICk guage wire to wire a switch that coses the open end of the fan relay
Last edited by originaladrian; Apr 19, 2008 at 11:26 AM. Reason: Automerged Doublepost
Old Apr 19, 2008 | 12:16 PM
biniecki's Avatar
I didnt find a how to but I did find this https://www.cobaltss.net/forums/show...hlight=fan+mod From the diagram it looks like i have to splice into the blue wire on fan1 and the gray wire on fan2 and run them back to a switch where i would ground them out. Is that right or did i misinterpret the diagram?
Old Apr 19, 2008 | 12:22 PM
i think tht thread got deleted... there are psts bout the thread... but i cant find it... i can take a pic if needed of how i did it.
Old Apr 19, 2008 | 12:24 PM
BigTizzle903's Avatar
that would be sweet, and does anyone have the link to the how-to? or is that the one that got deleted?
Old Apr 19, 2008 | 01:01 PM
biniecki's Avatar
I just looked at the car outside and there are only 3 wires that run the fans blue, gray, and black. Blue and Gray are the positive connections and the black is ground. However these are some pretty thick gauge wire and the diagram I found said to use 12AWG wire and run it to a 30A relays (didnt specify what relay#) just have a switch controlling ground to the relay inside the car and to run each fan separate. I don't want to have a switch for each fan I just want 1 that will run both of them and do I really need to use relays for this? Couldn't I just use a high amp rated switch with an inline fuse before the switch
Old Apr 19, 2008 | 03:32 PM
no just close the open end of the fan relay by giving it 12v. so it would be THICK wire (lot of amps) from 12v source, to the switch, to the open end of the fan relay using a regular fuse tap. ill post pics later.
much simpler and safer, once u see how its done, u will realize it really is that simple.
Last edited by originaladrian; Apr 19, 2008 at 03:32 PM. Reason: Automerged Doublepost
Old Apr 19, 2008 | 04:21 PM
biniecki's Avatar
Yea i guess i just need a visual to understand. Then I will go out tomorrow install the switch
Old Apr 19, 2008 | 08:18 PM
iv got to run, heres a pic of my fusebox, ill talk about it when i get back later tonight and answer any questions.
Old Apr 19, 2008 | 11:25 PM
alright, let us know when your back, this sounds like a sweet, easy idea
Old Apr 20, 2008 | 12:04 AM
biniecki's Avatar
If i understand correctly it as simple as just putting that wire in there and then running it to a switch that supplies 12V. The only question I have is if there is something already hardwired into that terminal of the relay stock so that you could tap into it elsewhere in the wire loom somewhere to make it look cleaner. However guessing from your previous comment about the open end of the relay im gonna guess that there is no wire ran to that terminal in the stock setup. I think if I do this I will take apart the fuse box and hardwire it to the terminal for a cleaner look. Also this way if I have to take it to the dealership they wont ask 50 million questions about what it is and why its there.
Old Apr 20, 2008 | 12:31 AM
yup, u got it
im just warning u, use correct wire,
you can just jump the relay to a 12 v source for race days and pull it out when u dont want it, but i like it always there, another option would be to wire it to a switched power source and have it always on when the car is on
Old Apr 20, 2008 | 01:21 AM
biniecki's Avatar
aight i will get some 12awg wire and hook it all up tomorrow. Do you know what size fuse i should use or where to find a constant 12V source around the dash area besides that cig lighter? I would use it but would like to tap into the inside fuse panel for power instead and just use one of those add a circuit adapters
Old Apr 20, 2008 | 09:42 AM
ya, well, each fuse box has a constant 12v power source, and there are a number of other places, (jump terminals, battery) for constant 12. i am actually thinking about doing what u did, but with all my stuff and making it nice and hidden by just tapping the wires under the fusebox.
Old Apr 20, 2008 | 11:40 AM
biniecki's Avatar
So does yours have a switch installed or is it wired direct and the fans are one whenever the car is on
Old Apr 20, 2008 | 12:23 PM
do you have any pics of the switch itself?
Old Apr 20, 2008 | 03:59 PM
ya, i just have a switch under my steering wheel. ill take pics later f u want
Old Apr 24, 2008 | 09:23 AM
biniecki's Avatar
For anyone that is interested I have started a how to on how to go about doing this. Instead of just putting a wire under the relay, I show how to wire it directly into the fuse box. If you want to see the half completed how to let me know and I'll send you a link to it. Once it is fully complete I will post it in the how to section for everyone.
Old Apr 26, 2010 | 05:49 PM
liamrh's Avatar
Interested as well, seems that a relay would need to be involved somewhere in there.
Old Apr 30, 2010 | 07:15 PM
liamrh's Avatar
Bump?
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
