DDM replacement bulb question
Old Dec 26, 2011 | 04:29 PM
winning_blue's Avatar
I got my 8k bulb replacement in..but these bulbs don't come with a plug. The side that on the original bulbs had a plug don't have that plug but 2 individual 'prongs' is the only way I can think of describing them. What do I do with these haha
Old Dec 26, 2011 | 08:19 PM
no one can help me with this? want to get these in tonight
Old Dec 26, 2011 | 08:21 PM
BPacak's Avatar
Vtec Rep
pics would help, but if its something like this
there should be a clip thingy that they plug into on your headlights.
Old Dec 26, 2011 | 09:26 PM
yeah more or less like that except mine are longer. That picture is how mine came, I plugged that plug in the picture in and had one leftover. I tried them both in each hole and did every combo there was and nothing.
Old Dec 26, 2011 | 09:38 PM
Maven's Avatar
def need pics....because what BPacak posted isnt even a bulb.....
Old Dec 26, 2011 | 09:43 PM
BPacak's Avatar
Vtec Rep
well they were attached to the bulb alright
Old Dec 26, 2011 | 09:48 PM
TommyP's Avatar
AWD > FWD
yep my bulbs when I had gen 3s had those attatched, I just rewired the harness on the gen 3s so that I didn't need those, made it much easier for me to pick up different bulbs.
Old Dec 26, 2011 | 09:55 PM
alright I'm gonna go get a few pics despite it being cold as **** outside. hope someone can shed some light then haha
Maven's Avatar
yeah if youve got bulbs that have those attached to the bulb you just chuck those, Ive got a whole pile of those things I take em off every set of H1s I use. But if the OP only has metal terminals on his bulbs hes gonna need to swap the plastic AMP connector over. If thats the case this is just one more reason why DDM sucks.
Old Dec 26, 2011 | 09:57 PM
TommyP's Avatar
AWD > FWD
I already know what you're talking about, You have to simple amp connectors. Before you had those and 2 spade connectors one one end a 9006 connector on the other end. The plug you're missing is the one that brent pictured.
Old Dec 26, 2011 | 10:00 PM
RooTBeeR's Avatar
in for pics
Old Dec 26, 2011 | 10:04 PM
here's one of the "replacements"
here are the 2 prongs
here's the only open plug left or the prongs
Old Dec 26, 2011 | 10:06 PM
StruttinSoul's Avatar
Just push them into the connector and electrical tape. Problem solved.
Old Dec 26, 2011 | 10:09 PM
TommyP's Avatar
AWD > FWD
you could have mentioned that these are for fog lights
Old Dec 26, 2011 | 10:10 PM
does it matter which prong goes into which side of the connector? I tried every possible way and tried to turn it on; nothing.
Maven's Avatar
cut off that rubber grommet, throw out the wires that dont attach to the bulb. problem solved.
Old Dec 26, 2011 | 10:11 PM
sorry, thought I mentioned H11 in original post.
Old Dec 26, 2011 | 10:12 PM
TommyP's Avatar
AWD > FWD
well now you should check your fog light fuse. but match up the blacks, and match the red to if I remember correctly the purple wire.
Old Dec 26, 2011 | 11:24 PM
throw out what wires??
Old Dec 26, 2011 | 11:39 PM
Maven's Avatar
If all you're replacing is a bad hid bulb you don't need those wires, they power the ballast. Just replace the bulb. If this is truly confusing I must he missing something. Remove old bulb from light, unplug old bulb from ballast. New Bulb goes in light. Two plastic connectors plug into the matching connectors on the ballast. Done. Literally as easy as replacing a light bulb.
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Extremespeed
Sep 29, 2015 04:34 AM
