Does stock head unit have rcas and remotes
Old Aug 10, 2006 | 02:21 AM
06CobaltssOrange's Avatar
i was wondering if the stock head unit has rcas and remote because i have a sub and amp sitting around that i could use!
Old Aug 10, 2006 | 08:49 AM
NoleafClover's Avatar
just get a new h/u...its worth it...
Old Aug 10, 2006 | 09:20 AM
SilverBalt's Avatar
i dont believe so... if u are going for upgraded sound system just get a new h\u like noleafclover said..
Old Aug 10, 2006 | 09:34 AM
chevotec's Avatar
No it doesnt have RCAs. but you can go to a local parts store,bestbuy..whatever and get a line converter. Basically, you splice into the rear speaker wires, and wire them to the converter. Then you have RCA outputs on the converter that you send to your AMP. Voila! Thats what I did to plug my 10inch sub and it sounds great. Then you just have to run a power wire to the battery,get a good ground, then send the remote wire to the front fuse box. You can get what looks like a mini fuse, but has 2 slots and a wire coming out. That lets you tap into the fuse with an extra circuit. Use the wiper circuit for this in the fuse box.
Sorry this may be confusing, but it`s really easy.
Old Aug 11, 2006 | 07:40 PM
tiny's Avatar
line in converter
the stock HU is pretty good, i used it with my system, and there is no loss in sound quality
Old Aug 11, 2006 | 11:40 PM
Originally Posted by tiny
line in converter
true, theres no loss....but a new h/u makes a world of difference in my books...not only better sound but better controls, way better controls....however it is ur call....if u like the stock look keep it..if u want good sound and controls...go new h/u
Old Aug 15, 2006 | 12:11 PM
chevotec's Avatar
One main problem i`ve found with the line converter, is that the signal coming from the speakers is not constant. For example, if you keep the sound low, the bass might be too loud, but if you turn the sound up, the bass might be too low. Other than that, i think mine sounds great. An aftermarket headunit will solve that. Make sure to get at least 4V preouts for the Amp. If you want bang for buck, keep the stock unit.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
agentirons
Oct 16, 2015 02:11 AM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
