Door Speaker Wire
Old Jan 10, 2007 | 01:02 AM
windsha's Avatar
Door Speaker Wire
Hello all, I have searched and searched for this, to no avail,so maybe someone can point me in the right direction. I was installing my new front door speakers and could not get the new speaker wire passed the door grommets. My question is this, How in the heck do you get the speaker wire passed the dang door wiring grommet? Any help would be much appreciated.
Sorry if this has been covered before.
Old Jan 13, 2007 | 10:18 AM
pursuit2dr's Avatar
I take it you are running an amp. Just splice into the wires before they go out to the grommet and use the factory wires to the speakers. Just another option. I have personally not done this, but it can be done. (I don't have am amp yet)
Old Jan 13, 2007 | 01:40 PM
fastfreddy7's Avatar
Pull the grommet out the the door and the door jamb, makes it much easier. Then when you re done, just pop it back in.
Old Jan 13, 2007 | 07:20 PM
SS SCHGD's Avatar
does anyone know if there is open space in the gromets to drill and run new lines? I think there was last time I was in there.
Old Jan 14, 2007 | 01:56 AM
Are you talking about the rubber accordian like grommet between the door and the body? If so, like I said, its very easy to pull it out of the door and the door jamb and then just feed the wire through.
Old Jan 14, 2007 | 02:45 AM
SS SCHGD's Avatar
there is a plastic end that connects at one of the grommets, I want to drill through that (it's where all the wires connect.)
Old Jan 14, 2007 | 02:48 AM
HackAbuse's Avatar
I used a long flat head screwdriver, stuck it through, then electrical taped the wire to the screwdriver, and pulled it back through
Old Jan 14, 2007 | 05:57 AM
SS SCHGD's Avatar
unfortunately, I don't think My 10 Awg speaker wire will fit through the holes in the plug without some drilling...
Old Jan 14, 2007 | 08:02 AM
EmperorJJ1's Avatar
then you know what to do... drill away (take pics of thr process and post a how to)
Old Jan 15, 2007 | 02:37 AM
windsha's Avatar
Thanks for all your help I was finally able to get the wire in, using the screw driver + tape method.
Old Jan 15, 2007 | 02:46 AM
xspyder85x's Avatar
just take a drill like i did and go though, its really easy.
Old Jan 15, 2007 | 03:08 AM
HackAbuse's Avatar
Glad to help
Old Jan 23, 2007 | 11:13 AM
cobi's Avatar
Why are you using such big wire?
Old Jan 23, 2007 | 07:48 PM
SS SCHGD's Avatar
As the Girlfriend says, Bigger is better....lol
I got a good deal on a roll of 10 awg speaker wire, 100' at $25 bucks.
and I may eventually want to sent full power to my components.
150 watts RMS, 600 watts Peak, so if I decide to send 300-450 watts RMS to them I don't want to have to change out wires. (and from what I'm told the components are under rated.)
Old Jan 23, 2007 | 08:03 PM
sunrise_mj's Avatar
whoa whoa whao... what are you doing?!
10gauge is very much overkill... what speakers are you looking to give 300/450 RMS?
a GOOD 16gauge wire would work perfect... even up to that kinda power. we've done it many times
and as for the ppl telling you to drill, dont... i made new A-pillars for my tweeters and i passed my wires right along with the stock door harness...
just open the door, pull the black rubber off... now use a flatblad to pull the white plastic out... theres a couple open spots in the connection. just pass the wire through there...
now when you pass the wire through the black rubber boot, theres a trick. tape the wire to a long (12") ziptie... and spray it with wd40. and slip it through... should have no problems at all..
there!
Old Jan 23, 2007 | 08:16 PM
SS SCHGD's Avatar
My JBL GTi's are rated at that. As for not needing that size, I know it's not required, but I have the wire and may decide to use it...I might end up with some Subs in the doors eventually too. I'm not worried about drilling into the gromet as long as I have the space, if there are enough of the open spaces together then I'll be fine. Do you know if there are a couple of those open holes next to eachother? By the way, thats a great idea with the zipties and WD40.
I have a roll of 10 guage stinger expert series speaker wires. And honestly, I would not run anything less than 14 in my own car. (weather its over kill or not, thats how I feel)
Old Jan 24, 2007 | 08:59 PM
sunrise_mj's Avatar
gotcha... well i ran two wires through (pos,neg)... i believe there was a couple extra spots... though i dont have power windows..
Old Jan 24, 2007 | 09:12 PM
SS SCHGD's Avatar
Thanks, are you the one with the 3sixty also? I'm going to be installing one soon and was wondering if you have the 7 speaker set up?
Old Jan 24, 2007 | 09:24 PM
smartmlp's Avatar
there!
Do you have any pictures of the a pillars?
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
