Double stock subs...
Ok, so i bought, for like $60 off ebay, another stock sub because mine wasn't working very well, but it turns out it was pretty much unplugged...long story...so i was wondering, if any body has attempted to use 2 stock subs...i was thinking, if i could, put it right across from the other one, somehow...so, my question is, how would i do this?...and i know i would need to get more wires and another amp...???????...
Won't fit on the other side. For one the sub is designed to contour for the wheel well of the driver side only... and GM never added the metal needed to mount the sub on the passenger side.
since we are on the subject of subs and what not, where(if we have one) is the stock amp? my ion had one mounted in the trunk right behind the seats and i can't seem to find it anywhere on the balt. i own an 06 ss/sc
As emperor said, it is in the dash... but I wouldn't bother really trying to get at it... you cannot really adjust it.
if its just about adding metal to make it work, that shouldnt be too hard. id love to see how it turns out
I wouldnt mess with the stock sound system unless you are just replacing the speakers and swapping out everything all together. Too much hassle for what you get honestly. It would be nice if the amp was in the back and could be easily replaced with a slightly better amp to get more beat out of the sub but then you'd need to swap out the sub too.
