is it easy to hook up the aeroforce gauge?
Old Feb 25, 2010 | 03:15 PM
chingajose's Avatar
i just bought a aeroforce gauge and was wondering how easy it is to install it.
Old Feb 25, 2010 | 03:16 PM
SS33's Avatar
VERY easy
hook up +pos power source, hook up -ground, plug into OBD2, for power/ground some people tap into the stock boost gauge. I pulled mine from the sunroof switch, as I chose hardwired my radar detector at the same time.
3 wires, voila
Lemme know if you have any questions
Old Feb 25, 2010 | 03:17 PM
ecotecon18s's Avatar
Pretty easy. There used to be a How-to.
Plug the big plug into the OBD port, find a switched 12v source (usually the pink wire off the boost gauge) and youre good to go.
Old Feb 25, 2010 | 03:21 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
How-to: https://www.cobaltss.net/forums/how-guide-43/how-install-interceptor-d-22220/
Old Feb 25, 2010 | 03:23 PM
BumbleBee's Avatar
easiest mod ive done
Old Feb 25, 2010 | 03:34 PM
chingajose's Avatar
thanks fellas i appreciate the help. ill let u know if i need help. now the obd connector can that go thru the gauge pod?
the pictures arent showing. do i have to take the pillar off to put the obd cable thru?
Last edited by chingajose; Feb 25, 2010 at 03:34 PM. Reason: Automerged Doublepost
Old Feb 25, 2010 | 03:51 PM
SS33's Avatar
You'll hafta pull the pillar for all of the wiring. Plug the OBD2 cable in and route it under the dash and up the side, (under the weather stripping inbetween that and the dash, and up into the cavity that the pillar wiring comes up through
Old Feb 25, 2010 | 04:01 PM
Take the A-Pillar off. Open the driver's side door. There is a little panel on the end of the dash (where the door opens). Open it. This will assist in pushing the wiring harness up to the A-Pillar area. Its all pretty straight forward from there. Wire it up, plug it in, and go. Make sure you remove the red jumper.
Old Feb 25, 2010 | 04:07 PM
SS33's Avatar
good call, I forgot that panel comes off. It's been years since I wired those
Old Feb 25, 2010 | 04:10 PM
recklessactn's Avatar
I've had an inty for a while and my display go from very dim to bright and sometimes just changes back and forth randomly, i think i need to ground it but what wire is the ground??????
Old Feb 25, 2010 | 04:14 PM
I don't remember the wire colors... but standard wiring colors should be Red (Positive) and Black should be the ground, iirc.
Old Feb 25, 2010 | 04:27 PM
SS33's Avatar
Yeah you need a better ground, if the boost gauge ground, or the sunroof switch isn't working for you. You can make a real solid ground on the frame for the center console. Just pull the panels off from the side by your feet and there is a not you can remove to make a solid ground.
I forgot when I added my WB I switched all my gauges to that ground. With just the Interceptor the sunroof GRD worked good for me, but it wasn't enough for the Innovate WB, so I switched all my gauges over to that one, and it works perfectly
Old Feb 25, 2010 | 04:47 PM
witch wire is the ground on the inty bc you have white green and red....
Old Feb 25, 2010 | 04:56 PM
Go to their website and find the instructions. Only advise I can give you... I don't remember.
Old Feb 25, 2010 | 05:01 PM
the only ground they tell you is the ground on the obd II connector
Old Feb 26, 2010 | 02:53 AM
NCC-2000's Avatar
Interceptors don't need a separate ground, they pull everything from the OBDII port, except for the external 12V power that goes to the red wire in the small plug on the back. The green and white wires are for extra sensors that the gauge can read.
Old Feb 26, 2010 | 10:15 AM
SS33's Avatar
Well there ya go, even easier than we said. It's been so long since I installed mine I guess I forgot. 1 wire, 1 plug, and you're set
Old Feb 26, 2010 | 10:29 AM
ebristol's Avatar
The newest models of the Scan gauge plug right into the ODBII port. No other connections are needed.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
OrangeCoba
Oct 1, 2015 10:00 PM
