Electrical Lighting Help
My Vac/Boost gauge has three wires that come out the back. One of them is the ground and the other two are for lights withing the gauge. There is a white wire that i coded silver in the Awesome picture and a Red one. The red wire illuminates parts of the gauge to be red and the white one illuminates things to be white. I was wondering if its possible to hook up the light to work with my parking light switch? Like The red lighting will only be one with my parking light (ambers) and the white one will turn on when my driving lights are on ( Night driving so the gauge is fully lighted.) Can anyone give me a good diagram on how to do this?
Wait so you want the option to light them up separately and control when they do and don't light up? If you want that, you need to wire it to a switch, and I have a how-to that includes how to do that...
Tap the red wire into the parking light wire and tap the white into the headlight low beam wire. That's the most direct way to do I would think. I don't know where said wires will be located in the cabin, but if you find them then I would do that, with proper fusing and such to protect the circuits.
exactly it would be a bitch but you could run the wires all the way to the headlights. fuse of course and just piggyback or if your afraid of too much current draw wire up relays but that shouldnt be necessary
I used to have LED's in my grille that I wired to the park lamps, I grounded to a bolt in the bay, and I just jammed the power wire into the fuse slot for the park lamps, had it for over a year no problems.
im not even sure how thats relevent to wiring up a gauge. but ill take ur comment and step it up a notch
i got a big ass banner that said **** wetbacks on one side and **** ******s on the other side put it on a big ass pole and drove around in the hood listening to racist ass redneck music and didn't get shot.... that doesn't make it a good idea thou does it?
i got a big ass banner that said **** wetbacks on one side and **** ******s on the other side put it on a big ass pole and drove around in the hood listening to racist ass wetback music and didn't get shot.... that doesn't make it a good idea thou does it?
oh i c.... my bad i was thinking u meant something completely different. i guess he could go to the fusebox for parking and headlight instead of direct to the headlight. although just shoving the wires in the slot is a bad idea still.
z28addiction
Sep 28, 2015 12:03 AM
