EmpJJ starting Door Pods
Agreed I hope we can see more of this. I am wanting to do something similar this summer. I started on the rear deck before it got too cold out but I still have some stuff to finish on it other than getting it painted.
Sub'd......... this is going to make an awesome summer project, going to do the doors in a smaller version probablyl go with 2 6 1/2 inch in the doors, and probably do 2 8's in the rear panels. Great job btw, love the blue kevlar!!!
do it up man. but then your wall would cover them
due to the pods? mmm maybe 2 lb? but theres a sheet and a half of lux liner in each door (each sheet weight in at 10.8lb... and what id approximate at 10sqft of damp pro per door. probably another 4-5lb
sounds about right. idk it feels heavy and really hurts when i open the door all the way (to the almost 90 degree position) and the wind slams it into my shins at 2x the speed of light
emp would you recommend spectrum or something like it that can be sprayed over the "foil" deadening? i want to get rid of some of the road noise and bring out my doors alot more without something drastic.
i wouldn't say id recommend spectrum over the foil deadening but ya you can do that. main problem with spectrum in the doors is window. u dont want to spray the tracks or anything like that. plus the foil deadener like damplifier is actually about 15% or so more effective then spectrum. so.
mine are screwed into the metal door and not attached to the plastic at all. the pod is light for how big it is but its still heavy and the speakers arent light either so they really need more support then the panel alone can provide
the same guy that built my pods also did a 3 way set in a mini cooper with the es-07, es-03 and es-02 but those are attached to the plastic door panel
thanks i think i need to appreciate them more myself. the wow factor has sorta worn off for me BUT assuming i can afford it this summer might spice things up for me and the balt
emp Ive read all of the links you have in you sig and you have put a alot of money and time into the car. I think everything u have done is awesome and looks amazing.
