Engine noise ?
Old Oct 13, 2007 | 05:07 PM
bluebalt's Avatar
Engine noise ?
After installing my amp,Ihear motor noise real bad.What can i do to fix this problem?
Old Oct 13, 2007 | 05:09 PM
Black SS/SC 06's Avatar
Find out where it is coming from would be a good start.
Old Oct 13, 2007 | 05:11 PM
bluebalt's Avatar
through the speakers
Old Oct 13, 2007 | 05:15 PM
You lost me
Old Oct 13, 2007 | 05:16 PM
njg5gt's Avatar
as in, your speakers are revving? lol
Old Oct 13, 2007 | 05:19 PM
bluebalt's Avatar
When I press the gas pedal they do.
Old Oct 13, 2007 | 05:20 PM
Weird!
Old Oct 13, 2007 | 05:21 PM
njg5gt's Avatar
ive seen something like this happen to my friends mazda. when he would step on the gas, if he was playing his iPod, it would sound like a supercharger whine. not sure but check your grounds?
Old Oct 13, 2007 | 05:32 PM
bluebalt's Avatar
Got my amp hooked to the battry ground.Cable is about 30" long.
Old Oct 13, 2007 | 05:34 PM
braddddddd991's Avatar
http://www.sonicelectronix.com/cat_i...e-filters.html
Old Oct 13, 2007 | 05:38 PM
Blurred Vision's Avatar
Its not ur car its probably ur ground wire. theres a thing u can but that hooks to ur rca cables to filter out the noise I think its a ground loop
Old Oct 13, 2007 | 05:47 PM
Bika's Avatar
Fail Less.
+1 blurred vision. it is ground noise.
Take your amp ground off the battery ground point and put it to the rear strut tower, or some other solid point on the chassis that is not just a random piece of sheet metal.
Old Oct 14, 2007 | 04:44 AM
EmperorJJ1's Avatar
how did you do your ground? is the ground on the car clean from all paint ect?
Old Oct 14, 2007 | 12:43 PM
Bandit2941's Avatar
If your amp is grounded to the same place the battery is you should have no trouble, provided the connection is solid and tight.
What are you using for RCAs? Do you have the RCAs with the big metal heads on the end? When I first installed my system I had an engine whine just like you. I finally tested it and realized that it didn't whine when the head unit wasn't installed in the dash. What was happening was the RCAs were grounding out to the metal bracket behind the dash and causing the whine. So if you have RCAs with metal heads, make sure they're not grounding out to anything.
Also, where is your head unit grounded? If it's through the harness, try running a new ground to a good piece of metal.
Stay away from those RCA line filters. They cause sound degradation.
Old Oct 14, 2007 | 12:57 PM
smurfy79's Avatar
I actually had a similar problem in a different car and a friend of mine told me that is was to do with the placement of the ground, something to the effect that is was picking up frequency noice from the alternator, anyway I moved the ground point and it seemed to fix the problem...
Old Oct 14, 2007 | 01:01 PM
M88ArRamadi's Avatar
Re route your ground wire......it shouldn't be longer thsn 18". Try another area to ground
Old Oct 15, 2007 | 12:04 AM
njg5gt's Avatar
just ground to the screw that bolts your rear seats in. its clos and not the battery
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
