Entering the world of SQL...Thoughts?
So I've had a "system" for a while (2 12" Rockford P3's 1000wRMS alpine amps and head unit)
And I've decided its time for some new components (Cobalt's faulty door speakers helped push my decision along too.
These are my options, any thoughts?
Alpine's SPX-17PRO
4ohm stable
has 100w RMS and 300 peak, (each side im assuming)
(Alpine Electronics of America, Inc.)
Found a set for $311
Rockford fosgate's T2652-S
100 RMS, 200 peak
4ohm stable
(Rockford Fosgate® - T2652-S)
Found a set for $190
Boston Acoustics Pro60SE and Pro50SE
Look about the same 125w RMS, but they look awful
(Boston Pro50SE)
(Boston Pro60SE)
50's are about $260
60'S are about $340
The RE XXX series is the only comparable one they offer.
150RMS
300 Peak
2 ohm stable
i dont know if i can bi-amp though
(RE AUDIO - Components/Fullranges)
$280
I was told to stay away from 2 ohm, but with subs the lower the better but apparently its not the same with companents...
Thanks
Alpine's SPX-17PRO
4ohm stable
100 RMS, 200 peak
4ohm stable
(Boston Pro50SE)
(Boston Pro60SE)
50's are about $260
60'S are about $340
150RMS
300 Peak
2 ohm stable
$280
Thanks
right i know what the acronym means i was just asking for a more detailed explanation of what your looking for... SQL is really used for subs and thats about it. id get into more detail but well **** it, ill just **** and get off the pot.... ive never used any of those speakers personally so idk
any amp would work with 2 ohm. but yes its a good idea to not run them off the radio alone (u really shouldnt run any component set without an amp) but thats not to say it wouldnt work
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
