factory amp into a project car
Old Jul 3, 2022 | 11:09 PM
primem's Avatar
For a project car build; I plan on using a 08 cobalt ss factory amp and subwoofer with an aftermarket head unit. The factory radio sends a "radio on signal" to the amp. Will the amp work without his signal? If not, any idea what the voltage is? 5volt? 12volt? TIA
Old Jul 6, 2022 | 01:35 PM
EmperorJJ1's Avatar
So many of us have replaced the stock radio in the balt with an aftermarket retaining the stock amp. The remote out using a standard wire harness will turn it on.
I do wonder why you would use the stock amp for anything other than a paper weight but im sure you have some good reasonings
Old Jul 6, 2022 | 11:10 PM
primem's Avatar
thanks for the info.
my $ is going into restoration...the sound system isn't high on my list at this point in time. the sub fit is an easy out of the way install....amp came with it $30 all in.
Old Jul 7, 2022 | 12:53 AM
EmperorJJ1's Avatar
gotcha yeah if you are using it in a cobalt upgrading from base sound then good enough. its setup a little funky so depending what all else you got, if the factory wiring for the amp is there for a simple plug and play or not... it may just make sense to do something semi custom with it.
Mr.09cobalt
Mar 27, 2012 05:19 PM
bdwarr6
Nov 11, 2011 03:51 AM
Magz_rule
Jun 22, 2010 08:57 PM
yellowcobaltss05
Oct 8, 2006 11:37 PM
chj69
May 25, 2006 01:03 PM
