Front Speaker Troubles
Old Jan 2, 2012 | 11:50 PM
HunterOnFire's Avatar
Front speakers aren't working in my 07 cobalt or the chime noises or anything? i know more people are having this problem. what is the issue? Please help.
Old Jan 3, 2012 | 12:11 AM
nabrian84's Avatar
did u change from the factory headunit? that would cause chimes to go away unless you got the aftermarket chime thingy.... the one i have is made by scosche... i believe metra makes one also.... i also had my drivers door speaker out for a while..... i opened up the door and moved the wires around and its been working ever since.... doubt this will help.... but its all the info i have
Old Jan 3, 2012 | 03:20 AM
EmperorJJ1's Avatar
right if ur stock then ur speaker is probably blown if aftermarket then u need those special parts
Old Jan 3, 2012 | 04:51 AM
BlueStang's Avatar
Water get down inside the cheap weather stripping and shorts out the spearker, Search previous threads and you will find this happens a lot
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
