Fuse to tap for constant 12v?
Old Oct 3, 2015 | 04:30 AM
EmperorJJ1's Avatar
Originally Posted by Decepticon06ss/sc
Finally found a thread to answer what I'm looking for. I didn't even know there was a another fuse box on the passenger side. So just for a refresher. For my glowshift wideband,for the constant 12v u can use the metal prong that sticks up from the fuse box under the hood that you use to jump start your car as a positive? And for the 12v switched I used the little metal tap a fuse thing and pick for an example the sunroof fuse? Then use the bolt on the driver side fuse box for the ground/black/negative?
add a fuse works yes but the sunroof fuse isnt constant. the bolt under the hood is positive. ground/negative would be any piece of metal thats part of the body of the car
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
