Fuse to tap for constant 12v?
Old Feb 18, 2014 | 08:47 AM
hatrik8's Avatar
I searched but couldn't find what I was looking for....
I want to connect an accessory and enable it to be on at all times unless I power it off.
I saw the info about tapping into a 2 wire harness, but it would just be easier just to use a fuse tap. Which fuse is best to tap for constant 12v?
Old Feb 18, 2014 | 08:51 AM
Bass_Waves's Avatar
Cigarette lighter fuse?
Old Feb 18, 2014 | 08:57 AM
hatrik8's Avatar
Where is that on the fuse box?
Old Feb 18, 2014 | 10:54 AM
Bass_Waves's Avatar
Inside the car. Passenger side. Remove the cover on the center console
I think. May be outside
Old Feb 18, 2014 | 11:01 AM
hatrik8's Avatar
The cig lighter fuse isn't in the fuse box?
Old Feb 18, 2014 | 12:08 PM
Balt_2.2's Avatar
You have 2 fuse panels in the car. One is on the passenger side at the very front of the center console. The other one is under the hood.
Old Feb 18, 2014 | 12:13 PM
If you want it on all the time connect it directly to the battery terminal or the terminal under the hood and put in a fuse holder for the correct amp fuse.
Old Feb 18, 2014 | 12:27 PM
Staged07SS's Avatar
Administrator
Administrator
I used an empty slot in the interior fuse panel to supply power to my gauges.
Slot 22 to I believe.
Old Feb 18, 2014 | 01:08 PM
hatrik8's Avatar
Thanks. Damn..... I was beginning to think nobody understood my question.
Is slot 22 constant all the time or just with ignition on?
Old Feb 18, 2014 | 01:45 PM
Staged07SS's Avatar
Administrator
Administrator
Ignition on.
That's why I used it for my AFR gauge and interceptor.
Powers the gauges on and off with the key.
Old Feb 18, 2014 | 01:51 PM
hatrik8's Avatar
Ignition on.
.......So are any of the fuses in the interior fuse box constant 12v? I need 12v with key off.
Old Feb 18, 2014 | 01:53 PM
Staged07SS's Avatar
Administrator
Administrator
cig lighter fuse.
Old Feb 18, 2014 | 01:54 PM
hatrik8's Avatar
If it would ever stop snowing and being cold out I'd go figure out the fuse slots. I was hoping I could just ask on here and then go outside and plug it in, not fart around kneeling in the cold snow looking at the fuse box.
Old Feb 18, 2014 | 01:56 PM
hatrik8's Avatar
cig lighter fuse.
Does anyone know what # slot on the fuse box?
Staged07SS's Avatar
Administrator
Administrator
I dont have them memorized sorry.
Shouldnt take long. Remove panel, look at fues layout, and find the numbered slot you need.
Old Feb 18, 2014 | 01:58 PM
hatrik8's Avatar
I didn't see it here page 5-94
http://www.vadengmpp.com/owners-manu...let-Cobalt.pdf
Old Feb 18, 2014 | 04:35 PM
kosmo43o's Avatar
Its going to b number 6 inside the car is 12v When car is off or u could just connect it to the post in the hood fuse box it like a screw it comes off and u will have 12v
Old Feb 18, 2014 | 10:35 PM
intel's Avatar
Would the windshield wiper fuse work for him?
You could also test the fuses yourself if you have a test light.
Old Feb 19, 2014 | 07:45 AM
EmperorJJ1's Avatar
no the wipers are acc not constant. just remember not to plug all kinds of BS into the cig lighters if you tap that fuse
Old Feb 20, 2014 | 09:57 AM
BlackielawlessSS's Avatar
Cig lighter fuse is under the hood, so is the trunk release button fuse.
Old Feb 20, 2014 | 02:48 PM
intel's Avatar
Yea, you're right. I misread the original post.
I second ECaulk's suggestion. I would just run the power source from the fuse post underneath the hood or from the battery in the trunk.
Old May 12, 2015 | 02:03 PM
dufcobalt's Avatar
you can plug 2 gauge in the same add cicuit?? because the slot #21 work very well but I need another one for my other gauge and I cant find...
Old May 12, 2015 | 02:09 PM
dufcobalt's Avatar
#21 and #22 works!!!
Old Oct 3, 2015 | 02:04 AM
Decepticon06ss/sc's Avatar
Finally found a thread to answer what I'm looking for. I didn't even know there was a another fuse box on the passenger side. So just for a refresher. For my glowshift wideband,for the constant 12v u can use the metal prong that sticks up from the fuse box under the hood that you use to jump start your car as a positive? And for the 12v switched I used the little metal tap a fuse thing and pick for an example the sunroof fuse? Then use the bolt on the driver side fuse box for the ground/black/negative?
Old Oct 3, 2015 | 03:27 AM
Squints's Avatar
Are you asking a question or making a statement?
