Fuse to tap for constant 12v?
I searched but couldn't find what I was looking for....
I want to connect an accessory and enable it to be on at all times unless I power it off.
I saw the info about tapping into a 2 wire harness, but it would just be easier just to use a fuse tap. Which fuse is best to tap for constant 12v?
If it would ever stop snowing and being cold out I'd go figure out the fuse slots. I was hoping I could just ask on here and then go outside and plug it in, not fart around kneeling in the cold snow looking at the fuse box.
Shouldnt take long. Remove panel, look at fues layout, and find the numbered slot you need.
I didn't see it here page 5-94
http://www.vadengmpp.com/owners-manu...let-Cobalt.pdf
Its going to b number 6 inside the car is 12v When car is off or u could just connect it to the post in the hood fuse box it like a screw it comes off and u will have 12v
I second ECaulk's suggestion. I would just run the power source from the fuse post underneath the hood or from the battery in the trunk.
Finally found a thread to answer what I'm looking for. I didn't even know there was a another fuse box on the passenger side. So just for a refresher. For my glowshift wideband,for the constant 12v u can use the metal prong that sticks up from the fuse box under the hood that you use to jump start your car as a positive? And for the 12v switched I used the little metal tap a fuse thing and pick for an example the sunroof fuse? Then use the bolt on the driver side fuse box for the ground/black/negative?
