Fuses/Amp Installation
Old Feb 29, 2008 | 08:30 PM
Element291's Avatar
Im kind of a noob when it comes to fuses (the sizes mostly).
Ok heres the setup.
- I've got a 300Watt amp installed in my car right now. It came with the wiring kit which has a fuse (one of those round see-through plastic casing ones). So a wire goes from the positive terminal of the battery, to through the fuse, then into the amp.
The amp has a normal 25 amp fuse inserted into it.
- I have an old 1000Watt amp I am wanting to install. It has two 25 amp fuses inserted into it.
Now the question is, Can I just remove the wiring from the 300Watt amp, and attach it to my 1000Watt amp? Or do I have to buy a different fuse for the positive wiring? (seethrough cased one)
Thanks in advanced.
Old Feb 29, 2008 | 08:38 PM
Forced SS's Avatar
try to match the the fuse under the hood to the total fuse in the amp.ex amp had 2 30 amp fuses so you need a 60 amp under the hood.
Old Feb 29, 2008 | 09:30 PM
Element291's Avatar
So the 300 watt amp has a 25 amp fuse built into, so the fuse from the battery is probably only 25 amps then right?
So I need to get a 50 amp fuse for my 1000 watt since it has two 25's in it?
Old Feb 29, 2008 | 10:43 PM
Forced SS's Avatar
cooking with krisco.But you can go up 5 amps if you want for sudden power draw. So you could use a 30 and a 60.
Old Mar 1, 2008 | 11:28 AM
Element291's Avatar
Ok heres what I am going to try. Let me know if its totally stupid or not.
I took the 50A fuse from under the hood for the ABS. Since I don't have ABS.
Now will I be able to place this between the battery and amp for my 1000watt amp?
Also, how much do these fuses cost?
Old Mar 2, 2008 | 12:31 AM
Forced SS's Avatar
Go to a Audio shop and get a in line fuse.It should be about 15 -25 bucks(with fuse). Are you useing 4 ga wire?
Old Mar 2, 2008 | 03:49 AM
EmperorJJ1's Avatar
5 bucks or so.... fyi car fuses and car audio fuses are worlds apart. I would stick with an audio fuse
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
