General Stereo FAQ - READ THIS!
Old Jul 20, 2006 | 07:46 PM
Tomtwtwtw's Avatar
Originally Posted by wikkymaster
how do i get the stock radio out??? i cant get the trim around it off, i thought it was just little clips i tried searching
Try this.
Old Jul 29, 2006 | 12:08 PM
StreetDreamz's Avatar
IF You Have Onstar And Wish To Retain It When Installing An Aftermarket Headunit You Must Use The Metra Part Number 99-3303.
Old Aug 16, 2006 | 03:06 PM
Lou's Avatar
Lou
I have an 06 SS supercharged and I want to know if i burn mp3's onto a DVD instead of a CD, would the factory system be able to play it?
Old Aug 16, 2006 | 03:32 PM
cdarnell's Avatar
no it is not a DVD reader only a CD reader
Old Aug 17, 2006 | 05:59 PM
chisledice's Avatar
Ok... so I said screw buyin the billion dollars worth or harness crap and got just the simplw wiring harness. I have everything hooked up as it should be, but I have no sound to my speakers. I have searched the hell out of a couple forums with no luck. I called Best Buy's intall bay and he asked if the blue wire with the white strip was plugged in, and I said yeah... so he was like... it should work... if not we will look at it for you for 50 bucks. Well... I have never had anyone install anything for me but me and I don't plan on starting. I just need some info that someone here might have.
Any ideas?!?!?!?!
Old Sep 10, 2006 | 09:50 PM
tricky1's Avatar
Any ideas?!?!?!?!
Repin your speaker wires, I got the wiring layout for the factory harness and using Ground(Black) on the aftermarket harness as a reference found my speaker pins were all in the wrong places. Here is the wiring layout for the stock harness:
Radio 12v red/white + radio harness
Radio Ground black/white - radio harness
Radio Ignition (GMLAN Serial Data)
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on same as power antenna wire
Power Antenna pink + radio harness
LF Speaker +/- tan - gray +,- radio harness or amplifier
Notes: If equipped, the amplifier is in the driver side rear quarter panel.
RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
LR Speaker +/- brown - yellow +,- radio harness or amplifier
RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
It sounds like you do have the switch wire figured out as you have power. So all you need to do is Repin your harness.
Old Nov 16, 2006 | 05:56 PM
cobalt38188's Avatar
More Info
hey man
just had a few questions to ask you real quick. What was involved w/ you putting your aftermarket headunit into your Cobalt?
I have read some different things and I have seen mixed information on this topic. I saw something that said you need a special wire harness to use w/ your headunit, it's Metra XSVI-2103
I've got a 06 ls cobalt also so I was just curious if you could fill me in on what it took to do this.
Thanks for your time!
Originally Posted by ted5986
i have an 06 ls cobalt and i put an aftermarket headunit in and there has been no problem setting my oil life counter. i have done it 3 times by myself
Old Nov 26, 2006 | 02:43 AM
averagewhiteboy's Avatar
Will the factory sub and everything work fluently in my Cobalt with the Pioneer option if I got a headunit? Aftermarket will alays sound better, but I also want an aux jack for my new Zune. lol. Eff FM adaptors. Eff em to hell. I have no problem with buying adaptors and stuff as long as it'll work. Thanks!
Old Nov 26, 2006 | 03:04 AM
xspyder85x's Avatar
not sure, i think you will have a conflict with the factory amp.
Old Nov 26, 2006 | 03:35 AM
Bah. Well, are my only options for an MP3 player a tape adaptor and an FM transmitter? could you hard wire anything or wouldn't it work because it's not made for anything like that?
Old Nov 27, 2006 | 07:35 AM
  #36
PursuitGT's Avatar
Everything will function as normal Including the Factory Sub.
Old Nov 27, 2006 | 09:24 AM
  #37
So there's no issues? All I'd need is the din adaptor, the wiring harness, the harness for the steering wheel controls, and the radio??
Old Nov 27, 2006 | 05:07 PM
  #38
kozmo71's Avatar
I also have an 06 cobalt ls.....i think it might also have to do with what sound system you have factory...like i have base cd player not the mp3...the peice i priced to fool the computer is around 130 bucks, but i was lucky and had a dumb computer and everything went nicley......but one question there are a few wires i have no idea what they are used for....for instance there is 2 constant powers on my wiring kit and only one works...it's odd
Old Dec 16, 2006 | 06:11 PM
  #39
ghewly's Avatar
what would be the best way to install subs and an amp in the trunk using the existing headunit for now?
Old Dec 23, 2006 | 11:17 PM
  #40
streetracinazian's Avatar
hey just wondering for you guys who did replace their stock headunits, where did you get your stereo harness/trim kits at?
edit: nevermind, found it on crutchfield.com!
Old Dec 24, 2006 | 07:18 PM
  #41
EmperorJJ1's Avatar
a local shop...
Old Jan 14, 2007 | 07:58 PM
  #42
p1llar's Avatar
I've got a question and can't seem to find the answer anywhere. Hopefully someone on here has done this.
I recently bought an Alpine Screen, single din size. This is NOT a CD/MP3/DVD combo.
I also bought a CD/MP3/DVD player thats single din so i can now play dvd's through it on my Alpine screen. I'm having a hell of a tough time finding the pieces i need to make it work, can someone please point me in the right direction.
Old Jan 15, 2007 | 06:20 AM
  #43
EmperorJJ1's Avatar
hmm sounds alot like what i will be doing... post up or pm me some the model number on the screen only....
most likely there is a brain to the screen but it may also be built in so depending on that the installation will be completely different
Old Jan 15, 2007 | 11:09 AM
  #44
p1llar's Avatar
Alpine CVA-1003, would it matter what modle number it is, they would use the same mounting kit right? i just don't know where i can find one that will support two single din units...
Old Jan 17, 2007 | 10:56 AM
  #45
p1llar's Avatar
^Anyone know?
Old Jan 17, 2007 | 12:22 PM
  #46
EmperorJJ1's Avatar
oh my bad i completely forgot about this... THe reason i wanted the model number is so i can see the specifics on hooking it up. IMHO you are not going to find a kit for 2 din units your best bet is to get the single din and modding it to fit the screen (you will probably need to cut a lil bit of that dash piece as well)
but hey after lookign up that model number it looks like a single din with a flip out screen... if thats right then you would just hook it up like a regular cd player
Last edited by EmperorJJ1; Jan 17, 2007 at 12:22 PM. Reason: Automerged Doublepost
Old Jan 18, 2007 | 02:04 AM
  #47
p1llar's Avatar
it is a single din unit, it is motorized as well, i have a mp3/cd/dvd player that is also a single din to go with it. I'm probally going to have to take it to future shop or something and have them rape me on the install...
Old Jan 18, 2007 | 08:01 AM
  #48
EmperorJJ1's Avatar
so wait you are actually installing 2 head units?
Old Jan 18, 2007 | 12:26 PM
  #49
p1llar's Avatar
Exactly.
I have a 1 din Alpine Motorized screen. It has NO CD player, or DVD player.
I have a 1 din Deck, that plays CD/MP3/DVD's- i'm using this to play stuff for the alpine
I have a 2600 watt 2 channel amplifer
I have 2 10" Bazooka subs at 450 rms x2.
Old Jan 18, 2007 | 12:32 PM
  #50
EmperorJJ1's Avatar
i must have got my info off then because when i looked up that alpine it said it was a cd dvd mp3.
