General Stereo FAQ - READ THIS!
Old Sep 23, 2007 | 06:36 PM
  #101
BlackLsCoupe's Avatar
Originally Posted by lorenwade
Not unless you know how to wire it and program it.
darn. i guess i got to get my money back. i got it because it had the ipod input jack on it.
Old Sep 26, 2007 | 01:51 PM
  #102
ClownFart's Avatar
i have tried a few different things to try and instal my aftermarket radio... i do not have on star i have the 2006 ss cobalt with premium pioneer sound system.. so i thought this was going to be easy. i just got the standard cobalt wiring harness and well that failed miserably... it would power on but no sound would come out and my DIC was acting all screwy. i determined that it had to have somethign to do with the second harness/plug thing that was just left unplugged to anything because the wiringharness (standard cobalt one) did not have the second smaller harness... i have no clue wha tthe second harness is anyway. but it seams to control or effect my DIC in some way (and speakers aparently cause they dont work when my thing powers on... ive called many places and they all tell me i need some kind of "special" harness which no one has in stock and they all can order it for me for like 100 bucks... ... i keep reading that u can use the cheap harness but HOW AND WHICH ONE! i thought i used the cheap one but aparently not... please advise as to what harness and then what after that... something about repinning? thanks... any help will be appreciated..
Old Sep 26, 2007 | 03:15 PM
  #103
pdub's Avatar
Please update this post. This is becoming very annoying. I'd update it if someone let me. PM'ing the thread starter.
Old Sep 26, 2007 | 08:01 PM
  #104
cobaltguy88's Avatar
I came back to see if it was updated... and.... nope.... its the same Lol
Old Oct 3, 2007 | 02:02 PM
  #105
Superdave420's Avatar
I am in the same boat, dude at best buy gave me a stock cobalt harness for my 06 ss/sc and it is clearly not the right harness. is there a solutionj to this, I have tried searching the web and I cannot find one :-(
06 SS/SC need radio harness adapter for installing a MEX-BT5000 bluetooth deck
Old Oct 18, 2007 | 09:21 AM
  #106
Dispute's Avatar
Will the cheap harness that works for the 05 and 06 work on the 07 at all?
If so what is the part number to the one that works for a 07 balt with the 4 speaker system?
i dont care about chimes i just want to use my new radio.
Old Oct 19, 2007 | 01:57 AM
  #107
EmperorJJ1's Avatar
no the 05-06 use a single harness the 07's use 2.... you must buy a 07 harness but they do make them in the cheap version that looses your chimes
Old Nov 23, 2007 | 11:26 PM
  #108
Synner's Avatar
Originally Posted by cybcow
Maybe he just doesn't know how to reset his oil life
its with the 07's, when you take out the stock headunit you can't reset the oil life threw the aftermarket headunit, mine sits in my trunk under my sub an im too lazy to take everything out to reset it its freakin annoying....
Old Dec 5, 2007 | 10:23 AM
  #109
Vulcan's Avatar
Stock HU
07 G5 SE. Base radio MP3 with Ipod jack.
Replaced the speakers with Hertz, composites in front, 6x9 in the rear.
10" PG Octane ZR in ported box.
A pair of 2 channel Audison amplifiers with speaker level input.
All run through the stock head unit.
BEST SOUNDING CAR STEREO I'VE EVER HAD!
I've run top of the line Alpine, Panasonic, Pioneer, Eclipse, etc. I will only ever consider an aftermarket head unit for an older vehicle that lacks connectivity for modern technology. I now have an Alpine 9831 sitting on my floor waiting for a new owner.
The stock HU is damn good I must admit, It's just the surrounding speakers and lack of power that are the weakness.
Old Dec 10, 2007 | 10:51 PM
  #110
Nightfall831's Avatar
I don't know about any other models, but I know that for the 2006 Cobalt LS, w/o onstar or the pioneer system or anything fancy at all, you can take the stock head unit, no problem at all.
There may be a problem for different models, I mean, Crutchfield and Best Buy have to have some reason to sell a $200 dash kit...
As for my situation, all it took was splicing the yellow constant power lead from the aftermarket HU into the red constant power in the factory harness, a ground, and a fuse tap into the windshield wiper fuse in the passenger side fuse block.
Hope this helps, i know the whole situation frustrated me...
Old Jan 17, 2008 | 11:11 PM
  #111
j.ho7's Avatar
so for those of you that can't reset your oil life without the stock head unit. put the ignition into the "ON" position and then push on the petal right to the floor three times within 5 seconds of the first push. Almost all GMs can be reset this way.
Old Jan 18, 2008 | 03:10 AM
  #112
EmperorJJ1's Avatar
dic is in the speedo not the stereo so no such problems on the cobalt
Old Jan 18, 2008 | 05:45 PM
  #113
JoshRock's Avatar
Talking
Yea stealth numbers 1 and 2 are completely false if you have a 2007, if you change that factory deck the fuel gauge doesn't work and you cant use any of the buttons on the sterring wheel to go through the DIC. In fact the entire instument cluster acts funny if you don't use the LAN harness with the 07's. Also the door chime will no longer work either will the delayed accy, because the radio keeps the accy running and the chime is output through the front left speaker.
Old Jan 18, 2008 | 09:35 PM
  #114
Thumbs up
I have an 06 ss/sc ,Sony blue tooth deck. After getting stage 2 installed and an oil change they did not reset my oil life counter.. So I tried and could not.. I just did the throttle reset and it worked !! Sweet Thanks for that tip
Old Jan 18, 2008 | 11:24 PM
  #115
Nymostwanted187's Avatar
so i just installed my alpine head unit is it normal when i turn off the car for the stereo to turn off too?? cause i can only have it on when the engine's running.
Old Jan 19, 2008 | 05:05 AM
  #116
EmperorJJ1's Avatar
not really... how did you hook up the red switched wire?
Old Jan 19, 2008 | 11:12 PM
  #117
i hooked it up to the wiper fuse. is it supposed to be hooked up to the right or the left side of the fuse hole?
Old Jan 20, 2008 | 05:06 AM
  #118
EmperorJJ1's Avatar
not sure... you want it to be hooked up to the actual "fused" side. But if memory serves me correctly an actual fuse tap will be fused reguardless of which was its facing. a physical connecton wont
Old Jan 20, 2008 | 01:50 PM
  #119
i have it on the right side but theres another thread that has it on the left. im not really sure which one. another thing i noticed is that the wipers dont turn on when the key's on ACC. i have the base model so i dont know how to hook it up to the sunroof fuse.
Old Jan 20, 2008 | 04:38 PM
  #120
EmperorJJ1's Avatar
sunroof fuse is in all the cars its just not "used" for cars without them
Old Jan 20, 2008 | 07:07 PM
  #121
yea i've seen it on there. do you think if i stick a fuse in there and use it for the stereo it'll work??
Old Jan 21, 2008 | 10:43 AM
  #122
EmperorJJ1's Avatar
yes.
Old Jan 24, 2008 | 03:44 AM
  #123
2000cavy2.2's Avatar
hey guys. im thinkin about gettin a 2008 Cobalt SPORT. with the 2.4 and the 7-speaker pioneer kit. its not gona be the 6-disc in dash its just gonna be the regular 1 disc radio tho. i am going to be putting in a pioneer double din DVD player Model: AVIC-D3 SKU: 8242458. anyone know the exact parts i will need for this setup? i want all the factory options to work in it, like onstar and the sterring wheel controls and all that. i dont wanna go the cheap way and not get a harness of any sort. i want them all for the most professional build up. so if u guys can help at all it would be appreciated.
Old Jan 24, 2008 | 04:15 AM
  #124
EmperorJJ1's Avatar
u need a gm lan style harness along with the double din cobalt dash kit and a steering wheel interface module from PAC-audio
Old Jan 24, 2008 | 04:52 AM
  #125
u can order the cobalt without XM Radio and ONStar?
caz i saw some people with out the harnesses for this too???
caz i dont really want Onstar or XM.
do u have part numbers for the harnesses i need?
or again, where off the internet i can get em?
also, sorry to be a off topic, but can someone also answer this real quick for me too?
..if i get the sport package colbalt wit the 2.4l, can they order it from the factory without the 17" rims, and the spoiler? i have 17" rims for when i get the 'balt, so the cheap ones will do just fine, and i dont like the spoiler on the trunk. again im sorry for getting off topic.
