Gmos-lan-04 + kenwood ddx719
Old Nov 14, 2012 | 02:32 AM
HunterXero's Avatar
Question Gmos-lan-04 + kenwood ddx719
It has been a long time since I've been here. On my last visit I had a 2006 blk 2dr ls. Sadly, i have sold her. So what brings me here now you ask? My 2009 T/C w/ pioneer. I have had the car about a year now and have decided to upgrade my headunit.
project info:
Kenwood DDX719 7" touch DVD unit
Gmos-lan-04 (metra)
Color-matched (nickel) bezel from Metra
9x 90degree shortie RCA adapters (for clearance and have not arrived yet.)
Soon to have an electric antenna and remove/shave the stock rc car antenna.
Now, for the problem...
The system sounds amazing, test install went without a hitch, onstar and chime levels needed no adjustment and everything works great.
However.. I've noticed my stock pioneer Sub does not hit anywhere near as hard now as it did with my stock hu. I've done some bing/google n yahoo searches, a search on here and other forums. But i cannot seem to find someone with the same issue and worse yet, no resolution so in the event that i am missing something... (which im sure i might be)
I would like to ask you guys for help. Have any of you run i to this before? If so how did you resolve it? Or do any of you have any ideas that might help.
I Greatly appreciate any help you guys could provide. Thanks!
-HunterXero
Old Nov 14, 2012 | 04:06 AM
EmperorJJ1's Avatar
and you are using the rca connections? for the gmos to the radio
Old Nov 15, 2012 | 11:07 PM
HunterXero's Avatar
Yes, I am using the RCA connectors provides with the gmos
Old Nov 16, 2012 | 02:27 AM
EmperorJJ1's Avatar
unplug one left or right rca and tell me if the sub gets louder or quieter?
also do you have the high pass filter on or off on the kenwood
Old Nov 16, 2012 | 08:21 AM
HunterXero's Avatar
i will be unable to get to the back of the unit for a few days, work is gearin up for black friday.
however, here is how the install looks.
as for the high pass filter, i did not see an option while floating through my settings. any idea in where this setting is?
i'm also wondering if i dont have my gmos output turned up enough, my half volume lvl is around 26 (of 34.) to the point where my audio is almost completely unnoticable at level 16.
should i consider raising this?
Old Nov 16, 2012 | 07:08 PM
EmperorJJ1's Avatar
ya probably but id look into the high pass filter first. pretty solid that will be the main cause. check the audio menu vs the settings menu and see if u can find it there
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
Turbo6
Aug 27, 2015 08:37 PM
DK081985
Stuff
May 6, 2007 04:56 PM
ViSiONZ
Apr 14, 2007 02:05 AM
