good ignition wire?
Old Mar 25, 2007 | 01:37 AM
musifreak190's Avatar
good ignition wire?
Hey guys I am going to be hooking up a second battery in my trunk. I got the Islolator and now I need a high amp ignition wire to run to the isolator...I was told that the deck ignition wouldnt be a strong enough through a tap in the wiper fuse..does anyone know a good ignition wire (color) under the steering wheel or near the fuse box that I can run?
Old Mar 26, 2007 | 11:11 PM
Old Mar 26, 2007 | 11:27 PM
Xavipheus's Avatar
Try tapping the sunroof fuse
Old Mar 26, 2007 | 11:42 PM
ted5986's Avatar
brown wire in the ignition harness under the steering wheel. its ok if you dont power anything with it. if you need a good amount of power, use a relay.
Old Apr 11, 2007 | 11:40 PM
now you say brown wire in the ignition harnest?..does that mean i have to take apart the steering wheel or just unclip the plastic under the whole dash?......if one of you could please explain or put a pic of the ignition harnest?...i have an isolator waiting to be installed with an optima redtop to power my amps and cap..thanks
Old Apr 12, 2007 | 08:00 PM
Bandit2941's Avatar
Why don't you just use the wiper or sunroof fuse but run it through a relay?
Old Apr 12, 2007 | 11:40 PM
i was told that thats not a true ignition with enough amps
Old Apr 13, 2007 | 10:59 AM
mesatrin's Avatar
I run mine off the ignition into the head unit, and it runs off of the wipers. I run it through a relay and it works fine. This is the second car it has been in and I have run it the same way both times. I have used a DMM to test that the isolator is working like it should and all is well. You could probably even run it from your amp remote turn on if you really wanted too. The isolator is really only there so that the second battery is not in the circuit during the starting of the car and when the car is turned off. Your remote would technically do the same thing but I wouldn't really suggest doing it that way.
Old Apr 13, 2007 | 11:17 AM
Bandit2941's Avatar
That's why I said use a relay - if you run it through a relay, the source signal needs very little juice (the same effect as the amp turn on wire).
Old Apr 14, 2007 | 11:51 AM
so where do I get the relay, and what kind should i get?
Old Apr 15, 2007 | 08:36 PM
Bandit2941's Avatar
Should be able to get the relay at any auto parts store, or radio shack. A standard bosch relay should work just fine.
Here's some info: http://www.6066gmcguy.org/BoschRelay.htm
Old Apr 15, 2007 | 11:31 PM
thanks alot!!!!!
Old Apr 17, 2007 | 07:19 PM
now im confused on how this relay will get wired for my isolator?
Old Apr 19, 2007 | 06:15 PM
Bandit2941's Avatar
OK, you tap your windshield wiper or whatever fuse you are going to use as your "source" signal first (or the "switch" wire). Run that to terminal 85 of the relay.
Then, connect power directly from the battery (fused of course) to terminal 30. This will be your high voltage side that gets activated when the source goes hot. Then, connect the isolator to terminal 87 of the relay. Finally, connect terminal 86 to ground.
What this will do is basically connect the wire straight from the battery to your isolator whenever the source circuit goes hot.
Old Apr 19, 2007 | 11:56 PM
thanks alot seriously bandit! Ill post pics of what it all looks like when its done....
Old Apr 20, 2007 | 08:00 PM
any specific wire awg and fuse size i should be using?
Old Apr 21, 2007 | 01:11 AM
Bandit2941's Avatar
That all depends on how much amperage the isolator needs, and I'm not familiar with how those work at all. For the source signal (the wire from the wiper fuse) you can use a very small wire, since its just activating the relay. But on the isolator side, I'm not sure.
Old Apr 22, 2007 | 02:19 AM
once again thanks
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
