Halos work HIDs don't
Old Aug 21, 2012 | 05:00 PM
Frogstofall's Avatar
Having a funny issue all of a sudden. My halos work but the hid bulbs don't. They were working just fine last night. I checked all the fuses in the fuse box and on the wiring harness for the retros themselves. All fuses are good.
When I click the headlight control lever to the ON position I can hear something click in the headlights but the bulbs don't turn on. What is the likelihood that they BOTH burned out at the same time? I just can't imagine that would happen.
Any ideas?
Old Aug 21, 2012 | 05:10 PM
padlock's Avatar
sounds like a possible ground issue, so I'd check that first (possibly remove it then check for corrosion). The *click* makes it seem like your relay is functioning so my thoughts point towards the ground wire for the ballasts
if that doesnt work, undo the ballast connections and check for water in them. I had that happen to me once then I just taped them up after drying them and they worked ever since
Old Aug 21, 2012 | 05:56 PM
Thx. You might be on to something bc it did rain yesterday and I rarely drive it in the rain but I did yesterday so I will check that. The ground looked good.
Old Aug 21, 2012 | 08:24 PM
SlobatLT's Avatar
I also had that happen to me once. I thought they burnt out and i was pissed. unpluged everything and plugged it back up, called it a day. then randomly they worked the next day.
Old Aug 22, 2012 | 02:42 AM
Well I ended up replacing the relays and now they work. One of them looked a bit gross so I'm gonna guess they were getting wet and just finally burned up.
TedSS
101
Apr 25, 2016 10:46 PM
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
