Headlight Gen3 Hid instalation
Old May 29, 2011 | 01:04 AM
CanadaFrenchie's Avatar
Hi all
i wanna know how to instal hid kit on gen 3 headlight thanks
Old May 29, 2011 | 02:40 PM
can i put h7 bulb on it or its only h1 ?
Old May 29, 2011 | 03:10 PM
TommyP's Avatar
AWD > FWD
It's H1 only, for both the low and high beam
remove old bulb. put in new bulb. Connect bulb to ballast, and connect spade connectors to the ones that the stock h1 bulb connects to. connect ballast to relay harness. Relay harness will wire into the fuse box and use the fender bolt as a ground.
Old May 29, 2011 | 04:17 PM
i need a relay ? why some people tell me its not an obligation ?
Old May 29, 2011 | 04:19 PM
TommyP's Avatar
AWD > FWD
It's just a safety measure. A relay harness takes the extra load hids draw off your factory wiring system. You don't HAVE to run one, it's just a precaution.
Old May 29, 2011 | 05:49 PM
ok i take 35w or 55w ??
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
