Headlight help
Old Jan 28, 2016 | 11:51 AM
Dre Day's Avatar
Headlight help
My HID driver side went out. I keep blowing my low beam driver side fuse. I checked the bulb and ballast by swapping everything around, no go still don't work. Everything else on the headlight works fine. I have no idea what else to do. I read something about swapping the left and right relays to see if it's the relay that's bad but I have no idea which ones are the right relays also if anyone has any other ideas what it could be. I am mildly knowledgable about electrical stuff but I take direction very well. 😁. Any help would be appreciated.
Old Jan 28, 2016 | 12:52 PM
double clutch's Avatar
If you keep blowing fuses then your shorting out somewhere. Run through your harness and make sure all your wires are connections are good.
Old Jan 28, 2016 | 01:48 PM
Dre Day's Avatar
I didn't see anything obvious when I was working on it last night. Everything seemed to be in good order. The only thing I could think of is I guess the previous owner had halo headlights because I see little red what I think are quick connects right at the base of the harness? Could that cause the short even though there's nothing attached to it.?
Old Jan 30, 2016 | 08:42 PM
EmperorJJ1's Avatar
anything could cause a short. If you unplug the wires altogether see if it still blows fuses or not
Old Jan 30, 2016 | 09:14 PM
T-fog's Avatar
If the wire has power then yes it potentially can be a short, Also if it isn't sealed properly the wire can corrode causing high resistance in the circuit and/or could potentially break from being so weak from the corrosion.
Old Feb 15, 2016 | 07:35 PM
Dre Day's Avatar
I unplugged the whole harness and no fuse blew I also just unplugged the head light and no blown fuse. Does that mean the headlight harness is a bust and I need to buy a new one splice in to fix it? Or is there something else I can do?
Old Feb 15, 2016 | 09:25 PM
EmperorJJ1's Avatar
try plugging in just the harness not connected to anything and see what happens.
AKillEaze
Feb 2, 2016 07:59 PM
Cwjohnson1995
Jan 23, 2016 03:05 PM
omarsiphone
Jan 20, 2016 08:55 AM
Ben Blonde Rupprecht
Jan 17, 2016 07:32 AM
Crav3
Jan 12, 2016 03:38 AM
