headlights led ?
Old Apr 11, 2008 | 07:21 PM
Omnigear's Avatar
Talking headlights led ?
ok heres da bidnez the led on the 1st gen projector headlights i would like for it to blink when the turn signal is on and go about being on normaly after the blinker finish.
Old Apr 11, 2008 | 07:28 PM
06_SS_S/C's Avatar
so connect them to the wires coming off of your turn signal bulb.
Old Apr 11, 2008 | 07:35 PM
AROON02's Avatar
lol ^ uhm haha and duh
Old Apr 11, 2008 | 08:48 PM
Omnigear's Avatar
if i connect them to the turn signal lites wire woulndt that only turn on when i engage the turn signal? i would like it to be on when driving
and blink when turning
Old Apr 11, 2008 | 09:19 PM
TeDy's Avatar
Use a relay........?
Old Apr 12, 2008 | 03:46 PM
Omnigear's Avatar
so just have the wire from th turning signals and a wire from the headlights go on a relay?
Old Apr 13, 2008 | 07:05 PM
Shermen's Avatar
your turn signal is also the running light. havent you seen another cobalt at night?
Old Dec 17, 2008 | 12:45 PM
Element-X's Avatar
Not true, the running light is a 194 bulb and the turn signal is a bigger 3157 bulb. I just bought a set of projectors (Gen 3) and would like to do the same thing with the LEDs while changing the colors from blue to amber. Did the OP ever figure this out?
Running lights are always on. The turn signals light up with the headlights and then engage the second element during signaling. Because there are two elements in that bulb, I don't believe the wiring would work for what we want to do. (given that an LED only has one element) But if you use the blue wire going to your turn marker to wire your LEDs, they'll at least blink with the turn signal, but won't be always on after that.
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
