HELP anti theft system
Old Dec 10, 2007 | 08:19 PM
stonewall's Avatar
I bought a wrecked cobalt ss supercharged. I am in the middle of fixing it right now and have hit a little road block. I had the car up and running a while back. It was driving and moving around the shop fine. I then shut the car down to replace airbags, pretensioners, sensors, clockspring, steering wheel, and air bag module. When I was done I hooked the battery back up and it wont start. It wont turn over or anything. when you turn the key to start it then let it go the theft light comes on for a couple seconds then goes off. If anyone knows anything I would realy appreciate your help thanks..
Old Dec 10, 2007 | 08:22 PM
liolixli's Avatar
If you use the unlock remote it should turn it off. Try locking it again with the remote twice for the beep. Then, hit unlock two or three times. There is another combo to do something inside the car too, but I think the remote unlock will fix your issues.
Old Dec 10, 2007 | 08:27 PM
chevysalesman614's Avatar
i would try that, then if it dosent work, you can disconnect the negative terminal over night and try again. good luck
Old Dec 12, 2007 | 08:52 PM
stonewall's Avatar
Figured out the problem... Thanks for your help it actually ended up being a fuse problem!
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
