Help! Car Won't Start
Old Dec 24, 2008 | 01:59 PM
c06alt's Avatar
Exclamation Help! Car Won't Start
Well, I was trying to re-install an aftermarket radio into my 06 cobalt ls. I had it in once before than re-installed the factory radio because I was about to sell my car. I ended up not selling it so today I finally decided to re-install the aftermarket radio. All I did was plug in the new radio and hooked up the ignition wire to the radio fuse and next thing I knew my display was saying "service airbag", my wipers won't work, and the car won't start. When i try to start it, light with a car and a lock in yellow displayed. I checked every possible fuse and nothing stood out as bad. I know it's Christmas Eve, but if anyone has any ideas about what this could be, I would greatly appreciate it. Thanks
-Nick
Old Dec 24, 2008 | 02:07 PM
originaladrian's Avatar
-Nick
WTF????
no clue wht u meant or did there.
try resetting ur ECU, unplug ur bat for 20 or so min.
Old Dec 24, 2008 | 03:09 PM
c06alt's Avatar
yeah man, i have no idea what I did. I'm gonna try unplugging my battery now. thanks.
no luck unhooking the battery. I left it unhooked for about 25 min and still nothing.
Old Dec 24, 2008 | 03:12 PM
LaserBlue07SS's Avatar
if the light with the lock is on your theft deterrent needs to be relearned it sounds like to me.
Old Dec 25, 2008 | 12:16 AM
jbenso4's Avatar
happened to me....go through the fuses on the passenger side of the car...took me two days...dont just use a fuse tester pull them all out one by one and check them each....it is a very small fuse blown good luck
Old Dec 25, 2008 | 12:32 AM
outtamymind's Avatar
there's also another way to relearn keys so that your theft deterrent goes off, put the key to the on position and leave it there for half hour and then try starting it. but judging from your description i would say there is something else wrong
Old Dec 25, 2008 | 02:37 AM
EmperorJJ1's Avatar
anything different from the first time? sounds like something was hooked up to the gm lan wire. the service airbag light is a bitch thou
Old Dec 25, 2008 | 08:48 AM
jbenso4's Avatar
im tellin ya u blew a fuse.....i know for a fact
Old Jan 19, 2009 | 12:39 AM
HidKidSS's Avatar
free bump...im haveing the same issue an its not a blown fuse..
i tryed to use a scanner to read the cold it was throwing but it wont even read any other ideas on how to go about this issue?
Old Jan 19, 2009 | 01:13 AM
Spun's Avatar
Check the relays in the fuse box under the hood?
Old Jan 19, 2009 | 11:32 AM
HidKidSS's Avatar
yeah just check those an they seem to be fine...any other ideas?
t t t
Old Jan 21, 2009 | 01:54 AM
EmperorJJ1's Avatar
its probably the stock alarm. your key might have been erased from the memory and its not getting that signal or whatever it needs to start
Old Jan 21, 2009 | 11:44 AM
HidKidSS's Avatar
how would i go about fixing that becouse my car is fully tuned an its at the dealer right now getting fully looked over..would they have 2 reset my pcm? an delete my tune or is there another way around it?
Old Jan 21, 2009 | 01:58 PM
if its just a key learn they shouldn't reset your pcm as its not required on a key learn. thats if its just the key that was unlearned from the system.
EmperorJJ1's Avatar
im pretty sure they just have to relearn the key im not 100% sure thou
Old Jan 21, 2009 | 02:00 PM
MP Cobalt's Avatar
Are the keys stuck in the ignition?
Old Jan 21, 2009 | 02:14 PM
rockstar014's Avatar
might of shorted a wire??
Old Jan 21, 2009 | 03:23 PM
jbenso4's Avatar
the same thing happened to me.........its the ignition fuse in the fuse panel on the passenger side.......i had a service air bag warning tooo...iut was when i was installing my deck...you have to pull the fuse individually and check the bottoms of them
Old Jan 22, 2009 | 02:04 AM
HidKidSS's Avatar
this could be it...my cars in the shop so i will go check it out tomorrow an see what they say an have them check that fuse while its in there..an if this is the problem thanks alot in advance lol
Old May 10, 2009 | 05:59 PM
chu77's Avatar
Did you guys fixed it? Does a blown airbag stop the car from starting?
Old May 10, 2009 | 07:03 PM
Eaqleone's Avatar
I would have assumed it was the fuses because I had a similar problem but my key got stuck in the car and wouldnt come out for nothing, turned out it was a fuse. As for the airbag im not sure but I would think that it should still start, just maybe whatever set off the air bag may have done more damage than you thought that would cause the car not to start
Old May 10, 2009 | 11:37 PM
EmperorJJ1's Avatar
no..
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
