HELP h/u problems
Old Jan 12, 2009 | 06:15 PM
  #76
LiL RoB's Avatar
if you follow the yellow metra wire through the connector and on the car wire side it should be a red and white wire, im just trying to make sure the metra pin out is corret for the car
Old Jan 12, 2009 | 06:17 PM
  #77
dman090's Avatar
yah man i just went out and looked and there is a wite and red wire on the car side
Old Jan 12, 2009 | 06:20 PM
  #78
LiL RoB's Avatar
is the blue metra wire hooked to anything?
Old Jan 12, 2009 | 06:22 PM
  #79
dman090's Avatar
nope its for the power antenna, which cobalts dont have
Old Jan 12, 2009 | 06:27 PM
  #80
LiL RoB's Avatar
ok now the two grey speaker wires on the metra the lower one. what color is it on the car side?
Old Jan 12, 2009 | 06:29 PM
  #81
dman090's Avatar
grey wire on top, green on bottom
Old Jan 12, 2009 | 06:32 PM
  #82
LiL RoB's Avatar
discounect those two and tell me if you dic starts to work looks like your speaker pin out is wrong
Old Jan 12, 2009 | 06:33 PM
  #83
dman090's Avatar
the green and grey or the 2 greys on metra side?
Old Jan 12, 2009 | 06:35 PM
  #84
LiL RoB's Avatar
disconnect them both for now, disconnect metra green and grey from pioneer harness
Old Jan 12, 2009 | 06:37 PM
  #85
dman090's Avatar
so... is this gonna fix my problem?
Old Jan 12, 2009 | 06:43 PM
  #86
LiL RoB's Avatar
need to see if your dic comes back, then we will need to figure out the correct speaker wires on car side
Old Jan 12, 2009 | 06:44 PM
  #87
dman090's Avatar
pulling those wires out of the harness side wont **** anythnig up?
Old Jan 12, 2009 | 06:46 PM
  #88
LiL RoB's Avatar
dont pull them out just take the wire nut off you put to tie them together between metra and pioneer harness
Old Jan 12, 2009 | 06:52 PM
  #89
dman090's Avatar
oh ok
i was about to go pull those bitches out of there lol
ok just un did the white and grey wires
Old Jan 12, 2009 | 06:58 PM
  #90
LiL RoB's Avatar
is your dic working now? you may have disconnect the other speaker wires the green and purple ones those you can just unplug metra from car harness
Old Jan 12, 2009 | 07:00 PM
  #91
dman090's Avatar
plug radio in?
Old Jan 12, 2009 | 07:02 PM
  #92
LiL RoB's Avatar
yeah just make sure not to have the exposed wires hit anything, may put tape or even the wire nuts to protect them
Old Jan 12, 2009 | 07:10 PM
  #93
dman090's Avatar
dic worked with the speaker wires unplugged
Old Jan 12, 2009 | 07:16 PM
  #94
LiL RoB's Avatar
ok heres the problem you have the wrong metra adapter, the reason why the dic wasn't working was because you had a speaker wire wired to the gm lan comunications wire, you have two choices 1. get the right metra harness. 2.re-pin the one you have
Old Jan 12, 2009 | 07:17 PM
  #95
dman090's Avatar
how hard is it to re-pin
Old Jan 12, 2009 | 07:19 PM
  #96
LiL RoB's Avatar
its not very hard you will have to take the terminal out of the metra connector and move it to the correct cavity you will only have to do this for the speaker wires
Old Jan 12, 2009 | 07:20 PM
  #97
dman090's Avatar
how do the wires come out? do u just pull them out?
Old Jan 12, 2009 | 07:23 PM
  #98
LiL RoB's Avatar
there is usually a lil tab you have to release so the terminal slides out, theres usually a lil notch where you insert a terminal release tool or you can sometimes get a pick to release it
Old Jan 12, 2009 | 07:24 PM
  #99
dman090's Avatar
kool....so where do i repin them to?
Old Jan 12, 2009 | 07:28 PM
  #100
LiL RoB's Avatar
ill have to find a schematic i dnt remember, check and see if you have a grey and tanish color wires on the carside connector should usually be the first upper set on the connector
