HELP h/u problems
I agree with spun. try and not use the blue twists. if you cant solder then see if you can get some cripcaps or barrel connecters. twist and tape isnt that great, but then agian same with crimps
so should that be plugged into the battery wire coming from the pioneer harness??
bump for help
bump for help
Yes, I believe the yellows should be together and run your accessory wire to sunroof fuse. I grounded the unit right to a bolt on the chassis. I didn't run it to the black wire on the harness. Also, to bypass the unit, you can't just ground the wire. you have to run a relay or a switch. So unless you're doing that right now, I would run the green wire to the parking brake wire and just watch them while parked.
ok so i think im on right track now!
so 2 yellows connect
ACC wire gets a fuse(sunroof)
h/u gets grounded
harness gets grounded
green wire taps into e brake via switch
is all taht correct?
h/u gets grounded
I didn't ground my car harness. I just grounded the pioneer harness to a bolt. I wrapped up the brown, orange, and black wires on the car harness. But again, not sure if yours is the same on an 07.
ok but a ground wont hurt ill it?
also how do i do the switch?
so the green wire to the switch then ground the switch? not even touch the ebrake?
da
ewwf
da
ewwf
thats right dont touch the ebrake just chassy ground it.
h/u gets power
no sound
no video(but havent hooked up the green wire yet)
the guages and DIC dont work
guages stay at 0
dic says "-----------"
and i havent checked all my fuses
no sound
guages stay at 0
woah.... plug the cobalt wiring harness in and take a pic of that with the wiring colors easily visible.... im 99% sure i know the issue. simple wiring mistake.
oh and you dont need a relay for the vid bypass just the switch i included.
so you want a picture of everything plugged in except the actual radio in?
hope this si what u wanted
when you wire your park brake switch to ground you will need to flip the switch on-off-on so the image comes on, as far as no sound still trying to figure that one out, sounds like when you dont have the remote turn on wire hooked up to a factory amplified system
