HELP h/u problems
Old Jan 11, 2009 | 03:15 PM
  #51
stinkyfisherman's Avatar
I agree with spun. try and not use the blue twists. if you cant solder then see if you can get some cripcaps or barrel connecters. twist and tape isnt that great, but then agian same with crimps
Old Jan 11, 2009 | 03:32 PM
  #52
dman090's Avatar
Originally Posted by 06YellowSS/SCinSC
Does the harness you're using not supply a yellow battery wire? Why do you have the yellow wire off the pioneer harness wired to a red wire?
it has a yellow wire but on the labeling it says it is a "memory wire"
Old Jan 11, 2009 | 04:14 PM
  #53
thats just another name for constant +12v.
Old Jan 11, 2009 | 07:43 PM
  #54
dman090's Avatar
so should that be plugged into the battery wire coming from the pioneer harness??
bump for help
Old Jan 11, 2009 | 07:58 PM
  #55
06YellowSS/SCinSC's Avatar
Yes, I believe the yellows should be together and run your accessory wire to sunroof fuse. I grounded the unit right to a bolt on the chassis. I didn't run it to the black wire on the harness. Also, to bypass the unit, you can't just ground the wire. you have to run a relay or a switch. So unless you're doing that right now, I would run the green wire to the parking brake wire and just watch them while parked.
Old Jan 11, 2009 | 07:59 PM
  #56
dman090's Avatar
ok so the only wire that goes to a fuse is the red ACC wire off the pioneer?
Old Jan 11, 2009 | 08:02 PM
  #57
Yes, your accessory wire should be the only one to a fuse.
Old Jan 11, 2009 | 08:05 PM
  #58
dman090's Avatar
ok so i think im on right track now!
so 2 yellows connect
ACC wire gets a fuse(sunroof)
h/u gets grounded
harness gets grounded
green wire taps into e brake via switch
is all taht correct?
Old Jan 11, 2009 | 08:10 PM
  #59
I didn't ground my car harness. I just grounded the pioneer harness to a bolt. I wrapped up the brown, orange, and black wires on the car harness. But again, not sure if yours is the same on an 07.
Old Jan 11, 2009 | 08:22 PM
  #60
dman090's Avatar
ok but a ground wont hurt ill it?
also how do i do the switch?
so the green wire to the switch then ground the switch? not even touch the ebrake?
da
ewwf
Old Jan 11, 2009 | 08:30 PM
  #61
da
ewwf
you only need to ground out the p4000 not the 2202, if thats what your asking.
thats right dont touch the ebrake just chassy ground it.
Old Jan 11, 2009 | 08:33 PM
  #62
dman090's Avatar
well ive allready cut the ebrake wire, but i can just crimp it back together
so green wire to switch then the switch gets grounded?
Old Jan 11, 2009 | 08:35 PM
  #63
you got it
  #64
dman090's Avatar
ok i hope everything works.....
wish me luck
Old Jan 11, 2009 | 08:40 PM
  #65
please remember to disconnect your battery and hope it works
Old Jan 11, 2009 | 09:33 PM
  #66
dman090's Avatar
still didnt ******* work
this **** is getting so fustrating
bump for help
Old Jan 11, 2009 | 11:26 PM
  #67
Spun's Avatar
What exactly is not working?
is the unit getting power?
Is there any sound?
Is there any video?
Have you checked all your fuses?
Old Jan 11, 2009 | 11:28 PM
  #68
dman090's Avatar
h/u gets power
no sound
no video(but havent hooked up the green wire yet)
the guages and DIC dont work
guages stay at 0
dic says "-----------"
and i havent checked all my fuses
Old Jan 12, 2009 | 02:01 AM
  #69
EmperorJJ1's Avatar
woah.... plug the cobalt wiring harness in and take a pic of that with the wiring colors easily visible.... im 99% sure i know the issue. simple wiring mistake.
oh and you dont need a relay for the vid bypass just the switch i included.
Old Jan 12, 2009 | 08:12 AM
  #70
dman090's Avatar
allright man wil do
Old Jan 12, 2009 | 05:25 PM
  #71
dman090's Avatar
so you want a picture of everything plugged in except the actual radio in?
hope this si what u wanted
Old Jan 12, 2009 | 06:00 PM
  #72
LiL RoB's Avatar
when you wire your park brake switch to ground you will need to flip the switch on-off-on so the image comes on, as far as no sound still trying to figure that one out, sounds like when you dont have the remote turn on wire hooked up to a factory amplified system
Old Jan 12, 2009 | 06:02 PM
  #73
dman090's Avatar
dont have a factory amplified system....
Old Jan 12, 2009 | 06:05 PM
  #74
LiL RoB's Avatar
yeah i know thats the strange part about it, whats the yellow wire color on the car harness side?
Old Jan 12, 2009 | 06:07 PM
  #75
dman090's Avatar
you meen the one that is off the metra? it was a "memory" wire, but on the wire itself it said "12v constant" so i plugged it into the battery wire on the pioneer
