help with stock amp
Old Jan 8, 2009 | 12:58 AM
hostilito's Avatar
help with stock amp
does any body knows where the stocl amp is located??? and does any have a pic of it?
i install a souble din DVD headunit and i want to try to install the amp to it...
also, does any body knows if i can conect the stock pionner sub to a atermarket amp???
i really need your help
Old Jan 8, 2009 | 01:12 AM
Spun's Avatar
You can but I don't see any reason to need to get anywhere near the stock amp.
If your going to install an after market amp then you need to run all new wires for it, then just speaker wire to the sub, this can all be done in the trunk, only the RCA's and remote wire have to come from the HU,
The stock amp is on the fire wall above your clutch, way the hell up there, its silver and has heatsink fins on one side.
Its a bitch to get at and its not suggested, why don't you give us a detailed description of what yur trying to do, and we'll give you a few options, ones that may be easier then what your looking to do
Old Jan 8, 2009 | 01:26 AM
tony2toness/sc's Avatar
If your going to connect the stock sub to a differ amp you might burn the sub lol
Old Jan 8, 2009 | 03:28 PM
hostilito's Avatar
i already install a ftermarket HU, also a aftermarket 4 chanel amp and i alrraady wire te speakers and tweeters to the amp,,,, but the sub is not working i havent conect it to any where,
so what can i do, conect the sub to a aftermarket amp or can i conect he stock amp to my new HU????
Old Jan 9, 2009 | 07:13 PM
Spun's Avatar
If you want to connect the stock amp to the HU then you need a GMOS LAN adapter, it will convert the wires from the amp to RCA's to go to the new HU, if your car is a 07 or up then the GMOS LAN 04 is what you want.
Why not just get another amp and sub or better yet run your fronts off of channel 1+2 then bridged 3+4 together to run he sub
Old Jan 12, 2009 | 10:23 AM
EmperorJJ1's Avatar
x2 if you have the pioneer package you can hook up the amp turn on wire to get power for your stock sub. but i would go with an aftermarket one anyway. 2 channel bridged (sub ran in series)
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
