Help wiring H/U
Old Jan 7, 2009 | 09:26 PM
dman090's Avatar
Help wiring H/U
ok i just got my H/u in the mail today
i got the pioneer p4000 and the cheap wiring harness cause i could care less about door chimes.
now if i understand this correctly, all you do is plug in the new harnes to where the stock radio was plugged in at, then the other end of harness, speakers and the pioneer wires all crimp together?
help please!
bump for help
Old Jan 7, 2009 | 09:31 PM
cereal83's Avatar
Yes, you plug the wire harness into the plug that was plugged into the stock radio and then you crimp all the wires from the new head unit's wiring harness into the wire harness you bought!
Turn on the car, make sure all speakers and radio work and then mount new radio into dash and done!
Old Jan 7, 2009 | 11:08 PM
dman090's Avatar
thanks
waht about the video bypass
Old Jan 8, 2009 | 12:04 AM
kkanowitz's Avatar
Actually...your switched accessory +12v (RED wire) needs to be tapped into a switched fuse...wiper fuse should be OK.
The stock HU depends on the GMLAN system for the switched signal. The cheaper harness won't allow for that.
Solder for the best connection....crimping is ok, but do it well.
Old Jan 8, 2009 | 12:07 AM
dman090's Avatar
oh ok
so ur saying that i cant vdeo bypass with the cheap harness?
Old Jan 8, 2009 | 12:15 AM
kkanowitz's Avatar
Originally Posted by dman090
oh ok
Actually that was a separate subject from the video bypass. I was talking about the basic wiring of your harness.
I'm not familiar with getting around the parking brake bypass stuff so I can't say much about it.
Old Jan 8, 2009 | 12:16 AM
dman090's Avatar
oh ok
wellm gona be sing twist crimps instead of solder or regular crimps
Old Jan 8, 2009 | 12:19 AM
kkanowitz's Avatar
oh ok
That's gunna be messy but it should work...
Old Jan 8, 2009 | 01:06 AM
Spun's Avatar
For the Video bypass you need to put a relay in line
Use the amp turn on wire.
You could use a 528T (pulse relay) but its a little more complicated than just using a simple 5 pin relay
It needs a pluse from the parking brake, The unit is looking for the parking brake to on, then off, then on again. The remote turn on wire has enough of a delay on it to achieve this.
After reading your posts I got to thinking this might be a little over your pay grade if you know what i mean.
Might want to take it to a shop and have it done right, it will be worth the money, just DON'T take it to Best Buy, go to a local shop.
Old Jan 8, 2009 | 04:57 PM
dman090's Avatar
naw man i cad do all the wiring and ****, i just need to know if the speaker wires get crimped in with the pioneer harness and the other harness, and once i though about ti the video bypass looks easy
Old Jan 9, 2009 | 11:46 PM
Spun's Avatar
Well where else were you planning to crimp it to?
Old Jan 10, 2009 | 12:13 AM
Sarbae's Avatar
Wiper fuse should work. I think I used the sunroof fuse... my car doesn't have a sunroof anyway
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
