HID help needed
Old Jan 25, 2011 | 06:44 PM
ssyellow's Avatar
HID help needed
Hello all,
I recently bought 8k bulbs because one of mine went out. Heres my problem. I have two different ballasts which makes the lights appear slightly different colors but I'm fine with that. The problem is that the right (passenger side) hid likes to act up and flickers ever so slightly a few times every second. Its hardly noticable but if you look you can see it. Also, the passenger side bulb decides to turn off sometimes and can be turned back on at random if I turn the lights off/on. Any help?
-Nate
3rd gen projectors with 8k H1 bulbs.
Old Jan 25, 2011 | 06:57 PM
Neyo's Avatar
i used to have the same problem... solution new ballast
Old Jan 25, 2011 | 06:58 PM
ssyellow's Avatar
Funny thing is this is the side I just replaced with a new ballast a month or two ago hah.
Old Jan 25, 2011 | 07:35 PM
kidcrash603's Avatar
sounds like you need a relay harness.
Old Jan 25, 2011 | 07:41 PM
bbrewbaker's Avatar
Sounds like it's not enough power. You need to get a relay harness for the lights.
Old Jan 25, 2011 | 07:42 PM
gwatson650's Avatar
relay harness!
Old Jan 25, 2011 | 07:44 PM
09Sp0rt's Avatar
^^ yep
Old Jan 25, 2011 | 07:46 PM
mkulrey13's Avatar
Did someone say relay harness?! PM me.
Old Jan 25, 2011 | 07:48 PM
09Sp0rt's Avatar
lol^^^^^ thats funny i dont care who ya are. I think you sit there with 'relay' sitting in the search button and everytime something new pops up you reply
Old Jan 25, 2011 | 07:55 PM
denlou's Avatar
Why is everyones solution to HID problems a relay?
My first guess would be your ballast is a dud, but swap ballasts from one side to the other and see if that's the problem.
There could also be a bad ground, these electronic ballasts get pretty bitchy if they don't have a good power connection and will shut off for a bit until the internal fuse resets itself.
Or just install an all magical magnetic switch called a relay and live forever in Valhalla.
Old Jan 25, 2011 | 07:56 PM
ssyellow's Avatar
Someone said that a week or so ago when I asked them about this problem, just didn't want to spend the money right now haha. Thanks for the help everyone, appreciate it. I'm going to swap ballasts tomorrow and go from there. Damn these lights...
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
