HIDs vs radio reception...
Old Nov 18, 2012 | 06:54 PM
cobalt_sport08's Avatar
So I just got home and didn't have aux cord in the car so I was listening to the radio -_- and my reception wasn't **** but I could barely hear the local station that I normally like.( I do have the MPX shorty antenna) Once I got in my driveway I turned my lights off and the signal cleared up immediately... I tried it again to make sure I was crazy, with my headlights and fogs same result when my lights where on static / off no static.
Anyone with an idea why this is happening??
thanks!
Old Nov 19, 2012 | 03:44 AM
EmperorJJ1's Avatar
ground loop noise input? lol idk
Old Nov 26, 2012 | 09:21 PM
09TcSedan's Avatar
i run into that when i listen to AM radio. i turn my HID fog lights on and the static is crazy! also when i turn the steering wheel i get crazy static.
Old Nov 26, 2012 | 09:27 PM
LS6Rally's Avatar
Im having this issue as well
my thread: https://www.cobaltss.net/forums/prob...please-288921/
i found that i get even with the lights off, but if i flash the high-beams the issue goes away temporarily. i need to check all of my grounds, just haven't had time to tear into the car.
Old Nov 26, 2012 | 09:35 PM
z062007vette's Avatar
OP, I remember helping you out with you HID's a while back. Do you still have the same setup from before?
Another suggestion is if you still have the original antenna to give it a try. Just my thoughts.
Old Nov 27, 2012 | 01:33 PM
Yeah it's still the same setup, and I don't even know what I did with my old antenna ha. But I sorta think it has something to do with the antenna, I had some problems getting it setup, Idk maybe something has come loose
Old Nov 27, 2012 | 01:40 PM
padlock's Avatar
are you running relays on your HID kits? That would likely solve your issue
mkulrey13's Avatar
I have static when i run my HIDs. Im running all morimoto 3FIVEs with relays. I rarely listen to the radio anyways
Old Nov 27, 2012 | 01:48 PM
I never installed the relay kit and yeah same here I don't really listening to it unless someone doest like my music ha
Old Nov 27, 2012 | 05:30 PM
LS6Rally's Avatar
see if you still get eh noise while using a CD, i know i do, which would rule out the antenna
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
agentirons
Oct 16, 2015 02:11 AM
dieGone
Sep 23, 2015 10:20 AM
