high output alternator?
Old Jan 11, 2010 | 10:51 AM
foxcobaltss's Avatar
Question high output alternator?
Looking for a high output alternator for a LSJ, anyone know where to get one? When my bass starts hitting hard when its turned up my headlights start diming so I want to bump up the amperage.
Old Jan 11, 2010 | 11:01 AM
Brenticus's Avatar
Have you tried a capacitor?
Old Jan 11, 2010 | 01:09 PM
yep, still does it, anyone else have this problem?
Old Jan 11, 2010 | 01:16 PM
Tennpenn83's Avatar
i don't know much about stereos, how about a smaller alternator pulley?
Old Jan 11, 2010 | 10:17 PM
Brenticus's Avatar
i've heard that will strain your alternator. not sure.
Old Jan 12, 2010 | 12:19 AM
EmperorJJ1's Avatar
i have it somewhere in my e-mail but spun found one on ebay a while back. A better battery and upgraded battery ground would help alot too
Old Jan 12, 2010 | 06:42 PM
Spun's Avatar
http://cgi.ebay.ca/HIGH-OUTPUT-180-A...item3ef1d5a7c3
Old Jan 18, 2010 | 06:59 PM
ThiZo_19's Avatar
isnt it wierd that its rated at 180 amps. yet on the pic its telling u to put an inli9ne 100 amp fuse? technically if it were to surpass 100 amps the fuse would pop. and if its rated properly then ur gonna need to be swapping those 100 amp fuses quite ******* often lollllll!
Old Jan 18, 2010 | 11:59 PM
EmperorJJ1's Avatar
technically if the stock wire is still there then together they should "handle" 180a... but iffy still
Old Feb 15, 2010 | 09:43 PM
dom1013's Avatar
you guys think this alt would really make a big difference over the stock LSJ alt? That does really fit the LSJ's right??
I my amp has a fuse rating of 250amps....
Oh and does the alternator power wire run UNDER the vehicle or inside, I hoping under! haha
Old Feb 15, 2010 | 09:48 PM
beercan's Avatar
contact zzp man, i saw sumthin on their website about a high output alternator. Or if you are willing to spend the money, buy one from ohio generator.
Old Feb 15, 2010 | 09:51 PM
dom1013's Avatar
Will do...
Just sent Ohio Generator an e-mail about 20mins ago, hopefully I get a response tomorrow. I just wanna be able to wake this Hifonics BXi2610 up to get some decent power and I hear their power hungry.
Old Feb 15, 2010 | 09:57 PM
Cefaln452's Avatar
Great, im glad you choose Ohio Gen. Cant beat their quality, but if you do the HO alternator make sure you do the big three as well. Brutus amps are not that efficient and dont put the power out they say they do but honestly you should be alright with adding a spare battery. but if you want to do an alternator id do a spare batt as well for extra storage
Old Feb 15, 2010 | 10:13 PM
dom1013's Avatar
That's what I was thinking too, just don't know if I can squeeze two of the current optima I have out back, and optima doesn't recommend running different batteries out back so I'm at like a crossroad.
I'd definitely like to be able just to do the big 3 and add a spare Battery for now.....I'll probably definitely do the alternator just for the piece of mind for future upgrading though.
Any one have (2) Battery set-up in the trunk they can post pics of?
Old Feb 15, 2010 | 10:21 PM
Cefaln452's Avatar
dude... **** optima, honestly, get a car audio drycell, half the size, less weight and designed for what your trying to do... look up stinger's power or powerII batterys, kentik, soundquest batt... Im running th stock and a stinger power II with a rockford t1500-1bd and t600-4 and i have no problems, and that TRUE power... my birthcertificate states 1987 watts then pluss what ever my his amp does, its rater at 150x4 but i cant rememver what it actually does
Old Feb 15, 2010 | 11:16 PM
dom1013's Avatar
I agree bro...optima is really sucking.
You should pm me pics of ur set-up or post em in hear. I have the rockford bd1000 also and the birthsheet on that one was 1197rms, rockford definitely under rates their amps, I was gonna go w/that T1500 also actually.
I've been checking out the kinetics also, just need to know which (2) will squeeze back there and how to run the alternator wire for the big 3 because I've never did that before.
Old Feb 15, 2010 | 11:27 PM
Cefaln452's Avatar
im currently redoing my system and once i get it done i will... someone needs to show me an easy way to post pics in a thread or i would
Old Feb 16, 2010 | 03:14 AM
EmperorJJ1's Avatar
u already have them hosted cefaln?
Old Feb 16, 2010 | 09:28 AM
dom1013's Avatar
What model are those 2(for a dimensions reference)?
Would (2) 16v Batts work for an application like mine?
.....Technically, Im assuming getting a great alternator would kind of eliminate the need for 2 big batteries out back, I know it definitely wouldnt hurt to have them but just thinking in general here, right?
Old Feb 16, 2010 | 10:30 AM
nicksredline's Avatar
ide do the big 3 upgrade first, u would want to do a bat and an alternator because if not ur gona be straining one of the 2 because its trying to keep up.
Old Feb 16, 2010 | 12:27 PM
dom1013's Avatar
Do we still do a chassis to engine ground because our batteries in the trunk? And do you know if the factory alternator power wire runs through the interior?
Old Feb 17, 2010 | 01:19 AM
EmperorJJ1's Avatar
I doubt it but i do have one new hc16v for sale
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
