high pass filter dosent work
Old Dec 27, 2008 | 04:17 PM
brickloaf's Avatar
just got a new eclipse HU, and i was playing with the crossover settings cause i dont want the speakers to produce bass, but ive tried every setting and none of them cut off the speaker bass.
any ideas??
thanks
Old Dec 27, 2008 | 04:32 PM
Tank07's Avatar
EmperorJJ1
pm him he installs audio for a living and knows everything im sure he can help you out
Old Dec 28, 2008 | 12:41 AM
EmperorJJ1's Avatar
hear ye hear ye, i know all.... lol but seriously when i looked up the specs on the deck it only had a 100hz crossover not an adjustable one so there shouldnt be any settings to mess with. EIther way thou give me a couple more specifics, are you sure the filter settings are being saved? is the actual bass setting itself at 0 or higher? whats the eq settings you have?
Old Dec 28, 2008 | 01:13 AM
tvalentino's Avatar
i also do car audo installation... if u really want to get rid of the bass on certain speakers you can splice in bass blockers/capacitors on the speakers postive wire and it will take car of it 100%
Old Dec 28, 2008 | 01:49 AM
EmperorJJ1's Avatar
true but the caps also color the sound a lil bit IMO. They work but if you have a digital high pass it sounds alot better IMO
Old Dec 28, 2008 | 02:16 AM
brickloaf's Avatar
its hard to explain
you can select either HPF or LPF and then on the same menu you can select some kind of 12db slope for either the HPF or LPF....heres a link to the manual
http://www.eclipse-web.com/us/downlo...ents/3001.html
you click on the "sound adjustment mode" then go to the bottom and select "crossover adjustment (x-over) to read about it
Old Dec 28, 2008 | 02:28 AM
EmperorJJ1's Avatar
try selecting only the HPF and see what happens. give me a sec with the manual (i work at a eclipse dealer i should know this **** right?.... nope)
Originally Posted by brickloaf
its hard to explain
just read it... sounds easy enough. Just make sure to
press select on the x-over
enter to activate
enter to switch from LPF & HPF (stop at HPF)
and select one more time to turn it to the on position
Last edited by EmperorJJ1; Dec 28, 2008 at 02:28 AM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 01:53 PM
brickloaf's Avatar
enter to activate
believe me it sounds much easier than it is, the selection screen is just like 1 big line and you cant select a hpf or lpf unless the slope thing is activated.
ill keep trying though, should the filter cut out ALLL bass from the speakers?
Old Dec 28, 2008 | 02:00 PM
Tank07's Avatar
^^^almost all the bass i believe
Old Dec 28, 2008 | 02:01 PM
EmperorJJ1's Avatar
mmm sorta. no crossover cuts out everything. they are all slopes and the way it works is each octave reduces by the value of the crossover. so in your case, at an octave below 100hz its -12db
you should hear a noticeable difference thou
Old Dec 28, 2008 | 02:18 PM
brickloaf's Avatar
**** this, ive tried every possible way and made sure i saved it every time, it does absolutely nothing
Old Dec 28, 2008 | 06:12 PM
EmperorJJ1's Avatar
i dont know... possibly take it to a local audio shop? call/ e-mail eclipse
Sean Cummings
Jan 8, 2020 10:17 AM
Tdubbs
Oct 13, 2015 02:31 PM
jonnycat
Sep 19, 2015 12:58 PM
Regalgs
Sep 17, 2015 02:27 PM
