hooking up neon
Old Jul 11, 2011 | 01:30 PM
hopewillfall's Avatar
hooking up neon
Im looking to install red lighting to the inside of my front bumper so it shines on the intercooler making the graphic visible at night. Would it be alright to splice the wiring into the foglight wiring so the foglight switch controls both. I dont want to cut holes or add extra switches to the car. If this is a bad idea what would a better one be for installation?
Old Jul 11, 2011 | 01:41 PM
BooSSted's Avatar
I wouldn't power it directly from the fog light wiring. You can use a relay and run a power wire from the fuse panel and just use the fog light wire to turn them on via the relay. Same kinda way an HID relay harness works.
Old Jul 11, 2011 | 01:53 PM
Shibito's Avatar
I see you are in Michigan. Be careful if you do install this, it is illegal to have a red neon lit up on your car on a roadway.
Other then that, I agree with what BooSSted recommended.
Old Jul 11, 2011 | 02:14 PM
I had no idea, I appreciate that bit of info. Is it just red neon thats illegal or is it neon in general?
Old Jul 11, 2011 | 02:17 PM
EXsoccer1921's Avatar
red or blue on the front of your vehicle is illegal in pretty much every state iirc.
Old Jul 12, 2011 | 03:27 AM
EmperorJJ1's Avatar
yup impersonating a cop. hefty fine
Old Jul 12, 2011 | 03:31 AM
cmatthewb101's Avatar
In Ohio, you can have any color neon. But red and blue HAVE to be on the bottom of the car, and facing the ground. I'd think most states are the same.
Sean Cummings
Mar 9, 2018 12:26 AM
jcalvin1126
Oct 26, 2015 12:31 AM
OrangeCoba
Oct 1, 2015 10:00 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
