How can I fix rattles
Old May 12, 2008 | 08:46 AM
Z Speed's Avatar
well I decided to install my sub and amp after having it sitting around... I have noticed now that my rear speaker deck and rear view mirror rattle a lot. What have some of you done to cure this. I know the deck rattles against the window So i was thinkin about putting something in between the 2. Im Just looking for a solution to the rattles that doesnt cost a ton.
Old May 12, 2008 | 08:52 AM
Texas SS's Avatar
Dynamat of course and what I found that works good is 3m double sided foam tap it works good and low cost
Old May 12, 2008 | 08:57 AM
Z Speed's Avatar
I figured dynamat but were to place it? that stuff is expensive so I would prefer to place it were only needed. and your sayin put double sided tape between the window and speaker deck cover?
Old May 12, 2008 | 09:04 AM
twofknloud's Avatar
i would have to say DYNAMAT, then more DYNAMAT, but your looking for low cost
try your local home depot, in the roofing dept, they sell rolls of tar on one side, and like chrome on the other side, these rolls come in different width 4" 6" 8" 12" & 16"
i recomend the 8" you can cut down small pieces, just wipe down the section where you'll install it, then use a wall paper roller 1" wide and roll it evenly
an 8" roll comes in about 20feet long so 1 roll should be more than enough usually priced @ about $20.00 a roll
you dont need to slap it all over the place, go with the feeling knock here and there where you hear the rattle, thats where you need it
good luck hope this helps
Old May 12, 2008 | 10:04 AM
Z Speed's Avatar
If i need to I will go pick up a dynamat trunk kit from best buy or something... I have some off brand stuff that I got on ebay for my cavy. seemed to help a lil but I think I may go for the real brand stuff this time and just use whats left of the other stuff.
Old May 12, 2008 | 12:42 PM
xyankees214x's Avatar
If your gonna get dynamat, dont buy it from best buy. By me the dynamat trunk kit costed 190$ at best buy. i bought it from amazon.com for 80. OR you can try a local body shop. Auto body shops use dynamat all the time in repairs, im sure they can hook you up with a price better then best buy.
Old May 12, 2008 | 07:11 PM
Z Speed's Avatar
thats not a issue... I got a best buy credit card lol
Old May 14, 2008 | 06:06 AM
EmperorJJ1's Avatar
take off ur rear view mirror (unscrew and slip off) and throw a strip of dynamat on the stub on the windshield... slide it back on and cutoff all the excess that squeezed out.
Old May 14, 2008 | 09:33 AM
Z Speed's Avatar
Cool I would of never thought of that... I would of thought there wasnt enough room inbetween the windshield stub and the mirror mount
Old May 14, 2008 | 01:19 PM
07blackg5's Avatar
Slobodan Milošević
look up fat mat on ebay. its a reputable brand and you can get 22.5 square feet for like 50-60 bucks shipped, 50 square feet for 80 bucks shipped, and 100 square feet shipped for no more than 150.
a dynomat trunk kit is like 130 usd or something and its only like 20 square feet
Old May 14, 2008 | 11:08 PM
EmperorJJ1's Avatar
neither did i but after the screw loosening for the second time i took it apart and got creative. I put a lil more then just on the stub but quite a bit sqeueezed out and it was a PITA to put back on but after doing it to a customers malibu and just putting the single piece on the stub it worked the exact same. I haven't had any issues since
Old May 14, 2008 | 11:11 PM
InfinityzeN's Avatar
Second Skin works a little better, at least in my experience.
Old May 14, 2008 | 11:14 PM
EmperorJJ1's Avatar
i agree i used second skin myself but if the only way is the best buy card
Old May 15, 2008 | 08:37 AM
Z Speed's Avatar
picked up the dynamat xtreme kit... and going to use what I have left from when i did my cavalier.. I may end up calling around to see if I can get lil more if needed.... I decided to get a bigger amp Alpine PDX1.1000 for my type R. once I put that in the debate will be if i need another sub or not
Old May 15, 2008 | 09:24 AM
Spun's Avatar
If your already thinking about it, you know you will
Old May 15, 2008 | 09:31 AM
joeworkstoohard's Avatar
i have about 3 boxes of dynamat in my car... still rattles at idle... course, that could be the poly mounts and 7lb flywheel...
Old May 15, 2008 | 12:10 PM
krazycobalt's Avatar
If you are intrested i have 4 sheet of dynamat extreme for! looking to get ride of cheap....
Old May 16, 2008 | 08:52 AM
Z Speed's Avatar
problem is do i want another sub or do i wanna get another amp and new speakers lol..
lil update tho
tried the dynamat on the windshield stub and worked out stopped the rattling of the mirror but it still shakes lol.... got most of the trunk done just gotta finish up the side panels and the underside of the speaker deck.... next im probably gonna pull the headliner once i figure that out and proceed to dynamat the roof and the doors... but first i gotta get more mat lol
Old May 16, 2008 | 08:54 AM
Jackalope's Avatar
I got rid of all the rattles and squeeks in one shot. I traded the Cobalt in.
Old May 16, 2008 | 09:19 AM
Z Speed's Avatar
yea well I like my cobalt... just dont like all the rattles from the sub lol
Old May 16, 2008 | 09:23 PM
EmperorJJ1's Avatar
lil update tho
u cant stop the shaking... lol im not god here. The window itself is what is flexing and since ur mirror is attached it shakes. So to fix the "shaking u have to either brace the window or attach the mirror to something more solid. oh fyi dont know about u but my roof moves as much or more then the window so thats not all that great of an option
Old May 17, 2008 | 06:22 PM
Z Speed's Avatar
im gonna dynamat the roof next... Now its just more or less weeding out all the key spots
Old May 18, 2008 | 07:08 AM
Z Speed's Avatar
well stripped the whole interior and dynamated the whole thing.... I must say THIS IS AWSOME. I installed some mtx 6x9s in the rear speaker deck along with all this and im inpressed. Now im just waiting for some mtx components that I checked out to come in stock and I will be doing that also. All thats left is to dynamat the doors. So far Ive used ruffly about 40-45 square feet of check stuff I got off ebay a while back along with about 60 square feet of dynamat through the whole interior and trunk.
Old May 18, 2008 | 05:00 PM
EmperorJJ1's Avatar
wait 40sq on the whole interior?
Old May 18, 2008 | 05:54 PM
Z Speed's Avatar
I used most of the cheap stuff on more solid areas of the trunk... the roll was 50sq feet but I used some on my cavy so it was about 40-45 sq feet and I got 60sq feet of dynamat.... so for the trunk, and interior so far Ive used a total of 100-105sq feet of sound dampening.... and I still have the doors to do
jimbofug007
Oct 2, 2015 12:06 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
