How to-Disassemble dash board
Old Jun 30, 2010 | 12:22 AM
kevinj4891's Avatar
Exclamation How to-Disassemble dash board
i have a stupid rattle right where my center air ducts are, next to the passenger airbag. it sounds like theres a screw loose in a cup or something. i also found the other day a screw with built in washer on my passenger floor, cant think where it came from. i searched how-to's and couldn't find any how to's to disassemble the dash board so i can check it out. can anyone help?
i thought this would be the best place seeing as people disassemble their cars to do speakers, h/u, sound deadener, etc
Old Jun 30, 2010 | 05:40 PM
kevinj4891's Avatar
i was disassembling my radio again, and found 4 screws above the glove box. i took them out and had a little play. i believe i have more screws to remove. i would just rather see a how-to and get research incase i screw something up. anyone know how to take apart the dash?
Old Jul 1, 2010 | 04:00 AM
EmperorJJ1's Avatar
update this tomorrow and ill help ya. tired
Old Jul 1, 2010 | 12:48 PM
kevinj4891's Avatar
Emp.... UPDATE UPDATE UPDATE
so i believe i have to take off all my trim, remove 5 or 6 7mm screws, facing me, probably remove the phillips head screws holding the speedo cluster, then from there i'm lost/havn't gone further. are there clips or anything i need to watch out for?
does anyone one know what causes the rattle in there?
Old Jul 1, 2010 | 02:07 PM
stinkyfisherman's Avatar
This is what I had to do to remove my dash, just follow 1-6. There are gonna be 7mm bolts, philips heads, and 10mm bolts. Maybe a torx cant remember. Any questions lol?
Old Jul 1, 2010 | 08:50 PM
wkoalmc2011's Avatar
I am having the same rattle issue. When I am changing my head unit out do I have to take all of this out too?
Old Jul 1, 2010 | 08:57 PM
EcoTecDriver's Avatar
no way man, just the center trim and left and right trim
Old Jul 1, 2010 | 09:02 PM
Okay, but to get to the ac to see the rattling I need to do all of that correct?
Old Jul 1, 2010 | 09:03 PM
yup....
Old Jul 1, 2010 | 09:05 PM
It's only on setting 1 or 2 that it rattles, after that I don't hear it. My new sound system should drown it out though.
Old Jul 1, 2010 | 09:07 PM
ooo well this guy has the thought that something is loose in his dash, Your situation may lie from the compressor or fan etc other moving parts
Old Jul 1, 2010 | 09:08 PM
Probably a fan, it sounds like that is the problem, or something like paper next to it idk.
Old Jul 1, 2010 | 09:36 PM
EmperorJJ1's Avatar
theguard:
Hey man I saw that you were wanting to get your dash out. I recently did that to cover it all in suede. First off you need to remove the A-Pillars, there's a screw under the "airbag" plug. Then you remove the side panels where the doors cover. Then pull off the dash trim. Its actually really easy but pull perpendicular so as to no break the clips. Then you are going to need to remove the passenger airbag. There is a how-to for it but just remember to disconnect your battery and take out the fuse for the airbags. Then there are about 20 bolts, you need to remove them all (the piece in front of the dash with the windshield air vents has to be removed first, it's held on by clips alone) then take out those and pull up the dash. It's as easy as that. It took me a long time to actually find all of the information to do it. But I used this site and yourcobalt. Just thought I would help you out a bit so I hope this does just that. Have a good one!
-Kalen
chefhhr
Oct 26, 2015 10:36 PM
satisfied
Oct 19, 2015 12:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
vjoel2011
Oct 2, 2015 12:11 PM
Trav3480
Oct 1, 2015 08:17 PM
