HU Grounding
HU Grounding
I've read about different grounding locations for the HU and wanted to know if there is one preferred over the rest.
1.Black wire in factory loom
2.metal in dash
3.Running ground wire to rear batt neg.
or any other suggestions.
2.metal in dash
if your just installing a deck then the ground in the factory harness is fine. but if your adding a 4 channel mids amp then its a good idea to run the HU ground to the back to prevent ground loop
satisfied
Oct 19, 2015 12:35 AM
