HU Grounding
Old Apr 4, 2010 | 11:11 PM
comptekkie's Avatar
HU Grounding
I've read about different grounding locations for the HU and wanted to know if there is one preferred over the rest.
1.Black wire in factory loom
2.metal in dash
3.Running ground wire to rear batt neg.
or any other suggestions.
Old Apr 5, 2010 | 03:04 AM
EmperorJJ1's Avatar
if your just installing a deck then the ground in the factory harness is fine. but if your adding a 4 channel mids amp then its a good idea to run the HU ground to the back to prevent ground loop
Old Apr 5, 2010 | 09:22 PM
comptekkie's Avatar
Thanks Emperor. I will have a 4ch amp so looks like I will run the ground to the back batt.
Old Apr 5, 2010 | 11:05 PM
EmperorJJ1's Avatar
yup i would run it directly into the ground input for the amplifier. that way they are getting as close to the same "ground" as possible
ricklovin93
Aug 27, 2016 06:35 PM
Oct 20, 2015 09:56 PM
satisfied
Oct 19, 2015 12:35 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
SStevie
Sep 21, 2015 11:37 AM
