i need help asap
Old Mar 10, 2010 | 11:11 PM
ThiZo_19's Avatar
i need help asap
i have my avhp4000 dvd installed. going to the stock amp then speakers....
then i have my subs connected threw head unit via rca....
but everytime i put the volume past 11 on my deck it distorts like crazy my eq curve is good. anything i do it sounds like ****...im guessing stock amp is full of ****...i want to disable it compeletely for now and hook up my speakers to the HU directly...from what i remember in my previous car it powered some atermarket speakers well...the thing is right now inside speakers are stock...untill i get my infinity kappas and 4 chann amp....would removing amp and going straight to hu be good? has anyone done this? im sure i can go to like 30 with the volume and thats where i want my bass to be....11 for my bass is bs its practically off when all settings are on max i hate that ****....any help would be apreciated sorry for the novel
i personally think this amp was made to receive a low input signal from stock hu and with the output from the avhp4000 dvd its just to much for the amp to handle...
Old Mar 11, 2010 | 02:52 AM
EmperorJJ1's Avatar
that is correct. the easiest fix would be to splice rcas into the harness speaker wire to give the stock amp low level. but it also takes a bit of nonsense
theres a write up stickiy i did on an amp bypass but remember the tweets are active so u would loose ur front tweeters minimum
Old Mar 11, 2010 | 03:07 AM
reaper89's Avatar
i got the avh-4200dvd, with the pioneer system...and i can go up to 14-15 without distortion (but its so loud you gotta turn it down so your ears dont hurt lol) and for the bass, all i had to do was turn the gain up a bit on the amp, and it bumps just fine at those lvls
Old Mar 11, 2010 | 03:13 AM
EmperorJJ1's Avatar
right thats the other option as well. turning down the eq across the board and keeping the sub at +6
Old Mar 11, 2010 | 05:34 AM
reaper89's Avatar
my eq isnt turned down, and my sub is at +3. I havent even attempted to go higher cause +3 is good enough
Old Mar 11, 2010 | 11:10 AM
EmperorJJ1's Avatar
right i was talking about tz19
Old Mar 16, 2010 | 08:21 PM
ThiZo_19's Avatar
thanx jj man so far i havnt done anything... always working man never get a chance to work on my baby....but ive resorted to listening to it at 11/12 witch is ridicoulosly loud, and the fact that im still using the stock amplifier amazes me cuz that things so small....i have to go buy my infiniti reference and 4 chan amp that should be enough for now....dont need a crazy loud system just clear where i want it to be...to be compeletely honest in my previous car i had some walmart sony xplod speakers and they sounded way better than the same system on my pioneers....its the amp...its sad LOLLL
jj u da man dawg
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
