I need help removing rear seats
Old 02-22-2006, 12:21 PM
hardtocope's Avatar
my subwoofer box doesn't fit so i need to remove the top portion of the rear seats. can anyone tell me how they come off.. i'm been messing around with it for a half hour and can't figure it out??
Old 02-22-2006, 01:03 PM
italstalnprd86's Avatar
there should be a clip on the outerside towards the bottom where the seat is held in, the majority of them are like that, where the swivel hinge is, you should be able to use a screw driver to pop it out, then usually you pull the seat towards you, and it comes out of one thing, and then move it the oposite wat and it comes out of the other..... i havent done a cobalt backseat but im pretty sure it will be about the same
Old 02-22-2006, 05:20 PM
fljohnboy's Avatar
The bottom of the seat just push in and lift out. The back part is bolted in with I believe 4 bolts. If you are removing the back part from the car you will have to take off your battery cable, it slides through the bottom of the seat, bad design.
Old 02-22-2006, 06:12 PM
05REDROCKET's Avatar
It is very easy i did it my self in about twenty minutes. four bolts hold it in just watch the leather man.
Old 02-22-2006, 06:36 PM
tiny's Avatar
i did this on my car
if ur box wont fit through the trunk, it WILL NOT fit through the backseat
you would have to take off the rear speaker deck, if thats even possible
its an optical illusion, it wont fit that way, trust me, my box was 1/4" too big
Old 02-22-2006, 06:41 PM
Redberet's Avatar
Tiny, it will work, I've done it and fit a Bassworx Gloss Box in my Cobalt which is the exact height of the rear deck. To remove the rear seat just push it in and it will lift out, no bolts, then the rear seats backs will sit flush with the trunk floor.
Next take out the floor of the trunk and the spare tire and the stud... angle the box in using the spare tire well for clearance and you should be set...
Old 02-22-2006, 06:55 PM
hardtocope's Avatar
my box is a 1/4" to big as well. oh well it looks like it just gonna be in my back seat for the time being...
DANRICKARD
10-01-2015 12:08 AM
Tupp
09-30-2015 08:18 PM
nathan112i
09-30-2015 07:12 PM
Delta coupe
09-30-2015 08:11 AM
09-26-2015 06:44 PM
Quick Reply: I need help removing rear seats
