im in big trouble.. :(
Old May 28, 2011 | 10:28 PM
crispino's Avatar
soo.. i have a 2005 2.2. i have a headlight/foglight wiring harness out of an lsj. i hooked it up everything fit perfect. i also have dash trim from an lsj. so i plug the clip into the stock foglight switch and turned it on and nothing happened.. so i was testing the wires for power and they didnt have any.. before i knew it my cluster/hvac and all my switches stopped lighting up. my head lights still work as well as the dome light and such but the fogs and dash stuff dont.. and YES i check EVERY fuse under hood and pass. kick plate.. idk what else to do and i cant figure it out.. any and all advice would be great...
Old May 29, 2011 | 07:58 AM
FITZ07's Avatar
I know you said you checked all the fuses, but you might have over looked the one you need. Its labeled prk light fuse under the hood. I don't remeber wich position, but the dash lights are tied into it.
Old May 29, 2011 | 08:34 AM
heathkidder's Avatar
do u have hids? i member a ballast went bad on me and my gauge lights stopped working along with my parking light and fog light ... if not check prk light or fog light under the hood and then check for ur gauge lighting inside the car.
Old May 29, 2011 | 08:55 AM
flyy's Avatar
yeah probably just a overlooked fuse
Old May 29, 2011 | 10:46 PM
crispino's Avatar
I have hids but they work fine... and I checked that fuse
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
