install need help
install need help
hey guys i have just recently bought 2 alpine type-s subs both 12 inch im just wondering if i need to buy new deck or can i someone use stock and hook up a amp and do i have to do this a certain way? I m gonna get a Mtx 1000watt amp but need some help
thanks guys.
Last edited by stoon_cobalt_colby; Nov 21, 2009 at 02:57 AM. Reason: Automerged Doublepost
do the line out converter, its simpliest. whoever told you it doesnt work doesnt know what they are talking about. tap into the rear speakers, then run the RCA cables from that into the your amp input.
im not for sure on the dual amp....why do u need so many subs or is there just 2 subs in a dual box?
the remote wire plugs into something that turns on when the car starts. if want to do it the easy way tap into a fuse or something
i got 1 12 kicker cvr, 10 kicker cvr, 2 10 rockford fosgate and just gonna keep stocker in... yeah i might need to some how add a fuse
you can either go to autozone buy something called "add a fuse" pull the wiper or sunroof fuse and put that instead and run the remote wire to the back or if you have the pioneer system behind the radio tap the pink wire, attach a fuse inline and run the remote back
but the amps have fuses couldnt i just take those fuses out?
Last edited by stoon_cobalt_colby; Dec 1, 2009 at 01:55 AM. Reason: Automerged Doublepost
When I installed my sub/amp, I used these two guides on how to install/ remove the seats and everything else. Very good write ups with great instructions on what to do.
How-to sub install
https://www.cobaltss.net/forums/show...ight=subwoofer
How-to upgrade stock sub with original housing
Another great guide, but for replacing the sub in the same housing, very similar to the first guide.
How-to weight reductions(great on how to remove parts in the way)
Good luck!
How-to sub install
Good luck!
How-to sub install
Good luck!
How-to sub install
Good luck!
Delta coupe
Sep 30, 2015 08:11 AM
