Installed X930BT but screen won't dim
Old Dec 10, 2011 | 08:57 PM
ConroyCavScout's Avatar
I recently installed my Pioneer X930BT Nav unit. Everything is great except the screen won't dim when it gets dark out. My brain is fried from messing with this all afternoon. Can anyone help me out? Is there a setting I don't know about or is there a wire that needs to be connected. Any help would be great. Thank you.
Andrew
Old Dec 10, 2011 | 10:01 PM
Alright I did some more research. The orange-white wire on the head unit harness is the dimmer wire. What do I need to connect it to in the factory wiring harness to dim the display at night. Its ridiculously bright and distracting.
Old Dec 10, 2011 | 10:07 PM
Danny_Cin's Avatar
Not sure if it will work, but you can try wiring it to the rotary dimmer for the dash lights to the right of the steering column.
Old Dec 10, 2011 | 10:17 PM
I think its talking about a wire that only gets power when the lights go on. I just need to figure out what wire they are in the fuse box.
Old Dec 11, 2011 | 03:14 AM
EmperorJJ1's Avatar
there isnt really one in the fuse box. there is one in the bcm u could tap thou. what year is ur car btw
Old Dec 11, 2011 | 11:49 AM
its a 2008 ss
Old Dec 11, 2011 | 03:23 PM
EmperorJJ1's Avatar
you could get the expensive harness to get that without having to tap anything. otherwise ya u can tap something at the bcm
Old Dec 11, 2011 | 04:07 PM
i got the metra harness. there should be a wire in the hvac control harness that controls the lights on that. do you know what wire that is by chance? i don't want to run a wire over to the dimmer switch. and i do not have a volt meter.
Old Dec 11, 2011 | 04:09 PM
Validater's Avatar
I tapped into the illumination wire for the fog light switch, its 12 volts, and even if you dont have fog lights, you should still have the plug. just use a test light or something to figure out what wire is illumination. I think it was brown, but I forget.
Old Dec 11, 2011 | 07:33 PM
worked like a charm. thank you. and btw it is the brown wire.
Old Dec 11, 2011 | 10:24 PM
Validater's Avatar
Good stuff. Glad I could help.
Old Jan 2, 2012 | 10:39 PM
TGstring's Avatar
Hey guys,
I recently installed a JVC head unit to fit my needs and found that the metra harness did not have an illumination lead on it.
I'd like to tap into the brown wire fog light lead you mention, but I have a base 2006 Pursuit sedan and don't have any fog lights- where would I find the plug?
Thanks in advance!
Old Jan 2, 2012 | 10:43 PM
EmperorJJ1's Avatar
if ur electronically inclined think of how you would get an aftermarket alarm to control the lights
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Sep 25, 2015 06:06 PM
