Installing additional amp w/ pioneer system
Old May 2, 2012 | 11:18 AM
Prestige_Worldwide's Avatar
I just purchased a Sound Ordnance M1350 Mono Amp to power my JBL-GTO804 I am using to replace the factory pioneer 8" sub. Now I was told on the HHR forum I am on that I can use the Kicker 09ZISL adapter to convert the low-level speaker wires into RCA inputs to run to the amp. Now my question is will this work using just two wires since I am just running one channel for the sub correct? I can't find a wiring diagram for the HHR w/ the Pioneer stereo so I cam not sure if it's the same as the Cobalts. I was told to use the Brown and Brown/White wire for the adapter, is this the rear left?
Old May 2, 2012 | 11:19 AM
07LSJ's Avatar
i know someone who will def. post here
Old May 2, 2012 | 11:22 AM
I hope I am trying to install the setup this weekend and I can't get a clear answer from anyone on the HHR forum. I know they said the pink wire was the remote but I can't find a wiring diagram anywhere for the HHR.
I am keeping the stock amp to continue to power all the speakers I am just using the new amp to power the new sub.
Old May 2, 2012 | 11:26 AM
07LSJ's Avatar
look around for a guy his username is emperor something.... hes really good with all this audio stuff. he has a thread of making his whole car like rattle proof or soemthing like that.
Old May 2, 2012 | 11:54 AM
Well I got this wiring diagram link from Crutchfield.
2006-2008 Chevrolet HHR with Pioneer Wiring Information
Since the stock subwoofer looks like it has dual coils should I use all four wires in the adapter?
Old May 2, 2012 | 11:56 AM
07LSJ's Avatar
i have no idea... wait untill someone with the knowledgable info chimes in
Old May 4, 2012 | 01:48 AM
EmperorJJ1's Avatar
it is best to use all 4 wires but not necessary. The reason you want to use all 4 wires is in case a song is using stereo effects on the bass or entire song to make sure you get all the audio you should. But this is somewhat rare so you can use only 2 wires and it would work. you would just want to split them so the + and - are combined. But especially with a LOC like that kicker one might as well use all 4 wires
Old May 4, 2012 | 07:56 AM
So should I go ahead and just tap into the right side rear speaker as well. I am using the wires coming from the factory amp to tap into. A guy on the HHR forum that recommended the kicker adapter said the rear speakers was already a low level signal coming from the amp so a Line out Converter with gain control was not needed. But he said he only used the left rear + & - I am not sure why?
Old May 4, 2012 | 03:46 PM
EmperorJJ1's Avatar
alot of people only use one side bc they are lazy and its easier. but what you said makes no sense. so your tapping of the stock sub thats a dual coil with 4 wires or your tapping off the stock speakers?
Old May 4, 2012 | 04:48 PM
Red face
Well the stock sub is a dual coil so it would have the 4 wires, can I use those with the adapter to run the RCAs to the Amp? I suck at car audio.
Here is a pic I found of what I have that someone took out of theirs.
Old May 4, 2012 | 09:46 PM
Alright so I pulled mine apart tonight. So the 4 wires running to the sub are not coming from the amp, they go directly to the sub from the wiring harness. Should I use these 4 wires for my adapter or should I use the left and right rear speakers after they exit the amp?
Old May 5, 2012 | 03:47 AM
EmperorJJ1's Avatar
use those 4 wires.
Old May 5, 2012 | 07:16 AM
Awesome, thanks! I will post results w/ pics.
Old May 7, 2012 | 08:53 AM
Alright, I got it all hooked up over the weekend. Everything is working and I need to tune it but I am getting a loud pop from the sub when I turn the ignition on, any idea what would cause this. I haven't put it all back together because I want to fix the popping, the ground seems good any thoughts?
Old May 7, 2012 | 02:27 PM
EmperorJJ1's Avatar
wheres the ground connected to? is there a ground wire on that kicker loc?
Old May 7, 2012 | 03:30 PM
No there is no ground on the adapter it was just the 4 + - connections. The ground I have is running from the ground on the body near the battery directly to the amp.
Old May 8, 2012 | 02:14 AM
EmperorJJ1's Avatar
hmm that sucks. try grounding the stock amp chassis to the ground you have for the new amp u installed and see if that does anything
Old May 8, 2012 | 08:26 AM
I will play with the gain and see if that is the cause, if it's not the gain, would a voltage regulator help with this? If I got this where would it be wired to the remote power?
5V Fixed-Voltage Regulator 7805 : Voltage Regulators | RadioShack.com
Old May 8, 2012 | 10:57 AM
EmperorJJ1's Avatar
no not really that wont really help
Old May 8, 2012 | 11:05 AM
I will call Crutchfield support and see if they have any suggestions, I suppose it could be the amp doesn't have a relay built in.
Old May 8, 2012 | 11:30 AM
Any suggestions on how to tune my amp, do you adjust the gain and filters with the head unit settings all set at 0 or flat or at what you would normally listen to them at?
Old May 8, 2012 | 11:43 AM
EmperorJJ1's Avatar
crossover you want at 80 hz or lower gain all depends. hu settigns should be how u have them normally
Old May 8, 2012 | 12:06 PM
Thanks, what are your thoughts on using the subsonic filter? I know Bass Boost just causes distortion but I have no experience with a subsonic filter.
Thanks again for all the advice!
Old May 8, 2012 | 02:54 PM
EmperorJJ1's Avatar
subsonic filter should be on especailly with an 8in sub. the subsonic filter is a reverse lowpass crossover. it filters out the freqs that the sub cant play and that your ear cant hear
Old May 8, 2012 | 03:09 PM
Mine is adjustable, is there a specific way to adjust it or just set the gain and adjust after that?
