Installing additional amp w/ pioneer system
Old May 9, 2012 | 03:03 AM
EmperorJJ1's Avatar
since you using a sealed box u can have it lower then ported. whats the specs of the sub?
Old May 9, 2012 | 08:56 AM
Prestige_Worldwide's Avatar
It's a JBL-GTO804.
8" 4-ohm subwoofer
polypropylene cone with Hi-roll rubber surround
power range: 50-200 RMS watts (800 watts peak power)
frequency response: 30-400 Hz
sensitivity: 91 dB
Old May 9, 2012 | 12:25 PM
EmperorJJ1's Avatar
so id set it to about 30hz maybe 3/4 or 2/3 the way up see how it sounds and adjust from there
Old May 9, 2012 | 12:40 PM
chefhhr's Avatar
Did you replace the Pioneer sub with the JBL?
Old May 9, 2012 | 01:33 PM
Yes, I pulled the stock pioneer sub out and installed the JBL powered by a new amp I installed. I had to modify the box a bit and add a spacer because the JBL has a big frame but it sounds so much better than stock and I haven't even put it all back together yet.
Old May 9, 2012 | 10:58 PM
EmperorJJ1's Avatar
glad its up and going for you did u get the pop taken care of?
Old May 10, 2012 | 03:53 PM
I need to get a battery for my Digital Multi-meter. Once I turned the gain down it stopped so I think once I get it dialed in it should be good to go. Thanks again for all the help, I really appreciate it!!
Old May 20, 2012 | 10:11 PM
Alright, I have a question...
I set my gain and everything using a DMM and had it sounding good, I went on a trip and really used the sub and amp for the first time and it was about a 3 hour ride. Towards the end of the ride the bass really started hitting harder and louder so I adjusted the bass down on the head unit. On the way home it started doing the same thing towards the end of the car ride is the amp possibly getting to hot? or is the amp and sub just getting broken in and I should recheck the amps settings again?
Old May 21, 2012 | 12:10 AM
EmperorJJ1's Avatar
probably both and yes id recheck the settings
Jan 12, 2016 12:01 AM
deviance
Nov 24, 2015 05:51 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
