Installing Infinity System
Old Sep 15, 2007 | 07:26 PM
lorenwade's Avatar
I started my install on my car. I have an 06 cobalt. I'm doing the speakers first. To install my 62.7i speakers in the front doors, all I did was use the factory speaker ring. I don't know if this will rattle or not, but I think it should be fine.
What I did is I cut out the old speaker and the plastic ring that sticks up around it. I pulled off the foam and screwed the install ring that came with the speakers onto the factory one. I'm doing the back speakers next, then the amb/sub and OEM Interface. I have to do the whole project slowly over the week because of my schedule... I have no time to do anything.
Anyway, enough rambling. How have you guys installed your speakers? What methods did you use? (And I have manual door cranks... what a pain in the butt)
Old Sep 16, 2007 | 11:11 AM
EmperorJJ1's Avatar
for my ss/sc the mounting ring was seperate from the speaker so taking off the old speaker and replacing was easy as pie
Old Sep 17, 2007 | 06:10 AM
lorenwade's Avatar
Lucky you. It was a pain for me, but I have all the speakers in now. I'm installing my JL audio cleansweep as we speak.
Old Sep 17, 2007 | 08:30 AM
EmperorJJ1's Avatar
let me know how it does....
Old Sep 17, 2007 | 04:13 PM
lorenwade's Avatar
I will. That back speakers were easy, but that back panel was so effing difficult to get out. I couldn't get the back pillars off unless I took all the side panels out too, which required taking off the seatbelts. I ended up leaning over the huge back panel laying int he back of the seat and reaching over to the speakers. Good thing the speakers were easy to put in.
Old Sep 18, 2007 | 05:18 AM
EmperorJJ1's Avatar
lol i just bent the **** out of it and scratched the hell put of the side panels... i wish i didnt do that now that i think about it
Old Sep 18, 2007 | 12:03 PM
SuperEco06's Avatar
what do you need that clean sweep for, if I may ask?
Old Sep 21, 2007 | 01:38 AM
EmperorJJ1's Avatar
i havent really read up on it but i think it just helps fix the imperfections of a Stock HU and im assuming has some eq adjustability... the 360.2 i got has a similar function included along with crossover, eq and delay
Old Sep 21, 2007 | 09:26 AM
MTXSS's Avatar
If your using the Stock headunit, I would recomend the Re-Q. It's easy to use and it works great. Thats what I used in mines and love it. It's easier to install than the JL clean sweap and the rockford soungate. Chk it out.. I ordered it online. It's a new item that not all stores has recieved it for. I paid $150 for it. Here is the website..
http://www.reqsound.com/
Old Sep 21, 2007 | 09:38 AM
EmperorJJ1's Avatar
ya um no... thats for adding bass to a stock system or something close to that. cant really compare to a cleansweep or 3sixty
Old Sep 21, 2007 | 09:41 AM
InfinityzeN's Avatar
Someone mention my name?
Hum, when you installed your front speakers did you put any sound damping material or rubber speaker baffles in? Doing that will tighten up the sound and help prevent any of those mild but annoying rattles from forming.
Old Sep 21, 2007 | 09:45 AM
MTXSS's Avatar
It not only increases bass. It also helps on the hig end. The main problem with stock headunit is lost of bass. Thats the main solution but it also works great with coaxles and seperates.
Old Sep 21, 2007 | 11:05 AM
SuperEco06's Avatar
i have some experience with the cleansweep, the thing was a nightmare beause it is auto-programming with that stupid CD, if it doesnt get a fullrange signal it wont tune right
Old Sep 21, 2007 | 07:15 PM
MTXSS's Avatar
Seriusly try the Re-Q. It works really good and I was suprised on how it worked. Real easy to install and so it doesn't need to be programed or recalibrated. Tune to your needs. If you don't like it, you can return it. Had couple of friends try in and they also had the same cleansweep and it's still in there car
Old Sep 22, 2007 | 12:42 AM
EmperorJJ1's Avatar
3sixty.2 ftw...
Old Sep 22, 2007 | 12:47 PM
SuperEco06's Avatar
I have heard good things about the 3sixty, problem with the cleansweep we did was it was in an audi with a bose system and because it was running six channels of audio, the cleansweep only has four channels of input so you need their optional summing module to bring the extra 2 channels in
Old Sep 22, 2007 | 01:23 PM
3.Sixty.2 FTMFW
Will handle 6 channels just fine.
Old Sep 22, 2007 | 07:14 PM
lorenwade's Avatar
Okay guys. The cleansweep is way easy to install. Was not hard at all. I installed it, the selfpowered Bssslink II with the speaker amp upgrade and everything. Sounds amazing. I'm really impressed. I didn't think it would turn out this well.
But if you're driving a cobalt and just want the clean EQ, then I highly suggest the cleansweep. And I only paid $100 for it... which is cheaper than all of the competitors. Try ebay.
The hardest part of the install was putting the back speakers in (getting the back panel off and reaching over to install the speakers, all without pulling side panels) and laying wiring under the side panels (also without taking them off).
If you guys have questions on how I did anything or curious about anything I installed, feel free to ask.
Old Sep 22, 2007 | 09:23 PM
EmperorJJ1's Avatar
ok i have a question.... pics pics pics
Old Sep 23, 2007 | 02:31 AM
lorenwade's Avatar
Hahaha. I'll post some soon.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
