Installing a new Head unit back plate
Old Jan 9, 2011 | 10:12 PM
mastersource's Avatar
I am installing an new head unit a JVC KW-XR610. I can get the unit to fit but I have to smash the back wiring against the metal plate that held the stock radio. What did everyone do with that back plate? Did you cut/ drill a hole for the wires and connectors or did you just leave it? If you cut / drilled what did you use to do it?
Old Jan 9, 2011 | 10:13 PM
08G5GT2.4L's Avatar
its screwed in on both sides. after cutting the plastic out you can simply remove that bar.
Old Jan 9, 2011 | 10:16 PM
Was it easy to remove? Also Where is the plastic? is it something that is easy to see and cut out? I have a 2005
Here is a pic I found where do I cut?
http://i576.photobucket.com/albums/s...altpics052.jpg
http://i138.photobucket.com/albums/q...install002.jpg
Old Jan 9, 2011 | 11:24 PM
troyss's Avatar
I had this problem and they make a spacer plastic piece that I got with my dash kit.. My radio was hitting that plate and the spacer fixed that
Old Jan 9, 2011 | 11:28 PM
Ting-ting's Avatar
omg lol the back peice has bolts holding it in there is 3 there a 7mm just undo and bam right out
Old Jan 10, 2011 | 03:23 AM
EmperorJJ1's Avatar
right remove the bolts and cut out the plastic... most are fine with just that. otherwise the actual metal bar comes out too
Turbo Johnny
Feb 21, 2019 09:41 AM
Tupp
Sep 29, 2015 11:07 PM
Turbo6
Sep 24, 2015 04:15 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
